Crimson Fox: Raising Awareness to Take a Break While Working
1,620
12
For a course we followed at KTH in Sweden, we were assigned to create an artefact which could change shape. We made a fox shape artefact, supposed to remind you to take a break from work or studying. The general concept it that the fox will display breathing like motions. When you are starting to work you pet the fox, indicating you are going to start with your work. At a certain point, when you are working for too long in a straight session, the fox starts to panic and breaths more heavily. When this happens you need to pet it in order to make it calm again. This will make you aware to take a break, which can be a short one like getting coffee or a long one like going for lunch, that's up to you.
If there would be a moment you decide to take a very brief break and want to continue to work after that, you pet the fox very briefly, indicating to the fox you that are continuing working. If you want to take a longer break, you pet it for a longer time. After that, when you want to start working again, you pet the fox shortly again.
Step 1: Step 1: Materials
Materials
  • (Fake) Leather*
  • Plywood
  • Cardboard
  • Aluminium foil
  • Glue
  • Needles and thread
Electronics
  • Arduino pro micro
  • micro usb to usb cable
  • Stepper motor
  • Motor driver
  • 2 small breadboards
  • 2 LED's of different colour
  • Wires
  • One 10MΩ resistor and two resistors of ~100Ω
  • 9 volts battery
  • 9 volts clip
* When using fake leather, make sure it does not contain any PVC. The leather will be laser cut, and PVC contains Chloride, which is toxic. When the fake leather does contain PVC or any other traces of Chloride, you can still trace and cut the lines with a scissor
Step 2: Step 2: Cut All the Materials
Use the lasercutter to cut all the materials according to the templates. In the files all the red lines needs to be cut and all the black lines need to be engraved. Use the right settings according to the lasercutter you are using, especially with the leather we advise to first do a test run to determine if the depth of the engraved parts are sufficient
When you do not have a lasercutter available, it is still possible to print the templates on paper and to cut/saw everything by hand, but it will take substantially longer.
Step 3: Step 3: Glue the Cardboard on the Leather
The cardboard serves as a support material for the leather so it does bent at the places we want. There is a matching shape of cardboard for each surface of the leather except for the hexagons. Glue them on the leather according to their shape. There should be about 3mm space between the cardboards on the edges that fold outward and almost no space between the ones that fold inward.
At the same time, slightly cut a little in the leather with a utility knife on the places it should fold inwards. This will make the leather fold more easy. Make sure you are not cutting completely through it!
Step 4: Step 4: Glue the Aluminium Foil to the Sides
In order to create a touch sensor so we can read whether someone is touching and petting the fox, we will glue 4 layers of aluminium foil to the sides to create a capacitive sensor. First sew the big side together and then glue the foil to the cardboard. Make sure to leave some room at the parts were it folds inside so the foil will not break. Attach a wire somewhere which can go to your arduino.
Step 5: Step 5: Make the Circuit and Upload the Code
Step 6: Step 6: Glue the Lower Part Together and Attach the Wires
Glue the gear on the stepper motor and the lower part of the plywood structure together and glue the stepper motor on top of that. After that you take your needle and threat and start at each corner in which the fox should fold inwards. Wind the wire around two times around the pin of the stepper motor itself with a little bit of tension to it before attaching it to the gear. Also, make sure to wind it counter clockwise.
Step 7: Step 7: Attach the Rest of the Plywood and the Electronics
  • In the lower part should be the place were you store the 9 volts battery
  • In the middle part should be the stepper motor
  • in the top part should be the arduino pro micro and the motor driver.
Step 8: Step 8: Sew the Open Edges of the Leather Together and Finish Up
Sew all the remaining open sides together and you are finished.
While you are sewing everything together, you can leave the micro usb to usb cable connected, so you can reprogram the fox if you ever want to.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    DIY Hacks and How Tos
    5 months ago
    That is really cool. I could probably use something like this to remind me to take a break once in an while.
