Cubic Bowl
Introduction: Cubic Bowl
A Wooden bowl for holding accessories and keeping small items in one place.
Step 1: Tools Needed
1. Pilers
2. Various size of hand file
3. woodworking Chisel
4.Orbit Sander
5. Band Saw
6. Sand paer
Step 2: Material Needed
A piece of 2”x 4” lumber wood
Step 3: Carving
I used a compass to draw a circle with radius 3” on the lumber wood as reference. I clapped the wood firmly onto the table, so it will be move while carving. I started with carving along the circle for making the edge more define. Then I carved toward the middle from the edge and carved deeper to form a bowl shape. The center of the bowl shape is 1.5” deep. The hollowing process was the most difficult and time consuming. It took me nearly 2 hours.
Step 4: Sanding and Trimming
I used 80 grit sandpaper to sand out uneven surface from carving marks, then used 200 grit sandpaper to make the surface more smoother.
I used the band saw the cut off the excess wood from both end, making it as square as possible. Then, I finished up with the orbit sander for smoothing all the uneven marks on all surfaces
Step 5: Waxing
Last step of the process, I applied wax to the bowl for protecting the wood from moisture and making it harder to attain with other product. Also, the coat of wax make bowl looks more shiny.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Maps Challenge
      Maps Challenge
    seamster
    seamster
    1 year ago
    Nice, simple project. I like it! : )
