Custom Auto Center Caps
I have a Jeep and of course I want to customize it. I had recently purchased new wheel for the jeep but I did not like the center caps that came with the wheels. So I decided to make my own. This is a pretty simple Instructable as most of the work is in the design.
Supplies:
  • 3D printer
  • Sandpaper
  • Paint
Teacher Notes
Step 1: Measure & Design
The first step is to measure and design the new center cap. I wanted something that was simple and flat. I knew the hole size and fixation mechanism based on the stock center caps. I've added the completed .stl file here for reference.
Step 2: Print & Sand
After the center caps are printed. I sanded with 180 grit sandpaper to smooth the surface.
Step 3: Paint and Install
After sanding, I painted with flat black paint and then simply inserted into each wheel.
CNC Contest
This is an entry in the
CNC Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    JackCarter
    9 days ago
    Ah, nice one. I'll think about it when i'll get a new car.
