Custom Cardboard Lightsaber
Introduction: Custom Cardboard Lightsaber
About: Hi, My name is Matthias. I like to program with Python 3, am interested in robotics, like to play around with electronics, and am an overall awesome person.
Hello there, my name is Matthias Horton and, in case you missed the title, this is an Instructable on how to make a cardboard lightsaber. Making one is very simple and can be customised as much as you want to make the deadliest piece of cardboard ever wielded by a Jedi (Sorry, you have to find out how to make a blade that can cut through basically anything, I haven't figured that one out yet). Now let's start building.
Step 1: Materials
You will need:
Flat piece of corrugated cardboard.
Cardboard tube from toilet paper roll.
Scissors.
Hot glue gun.
And a brain that works okay.
Step 2: Making It
FYI, the pictures can explain the process far better than I can write about it.
Handle:
Cut a slit up the middle of the cardboard tube.
Twist it up so it's smaller then glue it with the hot glue gun.
Keep it nearby.
Grip:
Cut a strip of corrugated cardboard about 2" long and 6" wide, it doesn't have to be exact.
Remove a layer off the corrugated cardboard so it shows the wavy layer.
Cut it into pieces with two waves wide per piece.
Glue them around the tube with a bit of space in between each.
Decorations:
Cut a strip of corrugated cardboard about 5" long and 1/4" wide.
Glue the strip around the tube, one at the top and one above the grip.
Button:
Cut out a small square piece and keep it close.
Cut out a small circle and split it in half
Glue the square and the circle together with the wavy side of the circle pointing in.
Glue the button to the tube in between the two decorations.
Step 3: And You're Done
Congratulations, you have just completed a cardboard lightsaber hilt. Now you can modify and customise it as much as you want. For some add-on ideas you could try a cross guard or extending the hilt. Good luck and "May The Force Be With You"
Cardboard Challenge
Cardboard Challenge
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Maps Challenge
      Maps Challenge
    2 Discussions
    Cool_Coder
    Cool_Coder
    Reply 1 year ago
    Thanks.
