Custom Foam Inserts | Laser Cut Foam
Introduction: Custom Foam Inserts | Laser Cut Foam
About: Trotec Laser Canada provides laser engraving and laser cutting machines for processing a wide variety of materials. Cut, engrave and mark wood, paper, metal, acrylic, leather, stone, plastics and many more. ...
Today we're laser cutting foam to create foam inserts for our industrial tools. These custom mat foam inserts are made from polyethylene foam (PE foam or PEF), which are laser friendly to cut and engrave. We use our Trotec Speedy 400 100w laser cutting machine.
We do advise to always double check the MSDS sheet of any PEF sheet you're going to laser, and ask our Technical staff if the material is safe to cut or engrave.
These foam inserts are ideal for organizing and storing industrial tools, instruments, promotional items, awards and any objects you would like to display in a professional manner.
Step 1: Measure Tools
To begin, we place our items inside of their container to find their positioning. In our case, we put our industrial tools inside of a box. Next, we take a picture of them from above.This image will be our guide when cutting the foam.
Step 2: Create the Graphic File
After, we import the picture we took into our design program. We first need to resize the image so that it's the same size as the actual box.
We create a rectangle with the dimensions of our container and align the photo with it. When it is aligned properly, we trace around our objects to make the cut lines. If you'd like, you can add spaces to make it easier to remove objects, add labels, etc.
Step 3: Cut and Engrave
Once we've created the image, we place our foam into the machine and send the job to the laser with these settings:
Engraving
Power: 70, Speed: 80, Passes: 1, z-Offset: 0.1
Cutting
Power: 30, Speed: 2, Passes: 3
Step 4: Assembly
Once everything's been cut out, we can put it all together. Layer the foam as needed, place your objects in their spots and you're done! An easy way to create a nice display for anything that you would like to show off.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    6 Discussions
    MikeM573
    MikeM573
    Question 1 year ago on Introduction
    What thickness and density of foam do you recommend? Lots of choices out there.
    Trotec Laser Canada
    Trotec Laser Canada
    Answer 1 year ago
    2.2 lbs./cu. ft. polyurethane foam (make sure you have a filter system for the polyurethane)
    jeffbrog
    jeffbrog
    Reply 5 months ago
    Above you refer to polyurethane foam, but at the beginning you are referring to polyethylene foam. Maybe you can make a correction or explain the two different kinds of foam?
    Fierypackman
    Fierypackman
    Question 1 year ago on Step 2
    Hi. What program did you use to draw the items please.
    joe.andolina
    joe.andolina
    1 year ago
    Thanks for the tip, now everything is in its place. I made a few cases that charge the items inside from an external jack.
