Custom Skateboard
About: Likes art
You will only need spray paint/airbrush a skateboard and paper.
Supplies:
Spray paint
Paper
Skateboard
Teacher Notes
Step 1: Remove Trucks and Grip Tape From Skateboard
Unscrew the trucks and carefully remove grip tapethe trucks
Step 2: Sand
Sand down the primer with 400-800 grit sand paper
Step 3: Make Splatter Point Spray
Remove yellow tab on spray paint nib and spray a first coat
Step 4: Spray
After applying the splatter paint put back on the yellow tab and spray again
Step 5: Now You Are Ready to Spray
Useing a wrag wipe off surface before spraying.for the sake of saving money i used my airbrush but you are welcome to use spray paint.
Step 6: Stencils
Now cut out some cool stencils
Step 7: Spray
Spray the stencle in white first so that the next color will show
Step 8: Out Line
Make shure what ever you out line your stencils with dosnt react with your paint
Step 9: Done
Final touches
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
