Cutting Handle for Bearing
Introduction: Cutting Handle for Bearing
This is an exciting project for someone with some basic technics skills.
Some time ago I purchased the bearing linear LM10UU. Im testing this bearing. In turns out is defecting. Because bearing wobble. Measuring defect very big = ok 1mm.
Im construct patent.
I developed construct cutting handle for proxxon model IBS/E.
Thanks to this patent we can fix the defect wooble bearing.
Teacher Notes
Step 1: Test Deffect Bearing
First step is measuring deffect.
Bearing wobble is about 1mm. This very big wooble.
Step 2: Step 1: Project End Printing Handle for Bearing
This is handle two types for bearing.
First typ is simple handle.
Second typ is clamping handle.
The project was made in Fusion360.
Printing for creality ender3.
Material: PET-G
Step 3: Step 2: Test Bearing in Handle.
Wobble test
1.First test in simple handle. Result ~1mm
2.Second test in clamping handle. Result ~1mm
Step 4: Step 3: Project & Printing Cuting Handle
This project: "cuting handle" in made to Fusion 360.
Printing Ender3, Material PET-G.
Step 5: Step 4: Applay Glue
This step, applay epoxy glue in handle for proxxon. Paste linear guide.
Step 6: View
This view bearing inside.
Step 7: Step 5: Maching Bearing Cutting
Cutting is slowly and precision.
Step 8: Step 6. Insert
Insert bearing to clamping handle.We screw the screws.
Step 9: Step 7: Test Modified Bearing
Result i very good.
Wobble decrease, is only ~ 0,1 mm.
Good Joob!!!
Step 10: Step 10: Watch the Movie
Fix It Contest
This is an entry in the
Fix It Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    seamster
    seamster
    1 day ago
    Nicely done!
    rsave
    rsave
    Reply 1 day ago
    Very Thanks!
