DDP CUTTING BOARD
Introduction: DDP CUTTING BOARD
Used old wood to make cutting board
Teacher Notes
Step 1: Cutting Board
Step 2: Step 1: Gather Materials
Find the type of wood you want
Step 3: Step 2: Cut Your Wood
After finding the type of wood you want set the table saw to 1 1/2 and cut pieces
Step 4: Step 3: Pick Pattern
After the wood is cut select the pattern you want
Step 5: Step 4: Glue Wood
Glue wooden strips together then clamp them and let dry
Step 6: Step 5: Run Through Plainer
After glue dried run through the plainer on one side to smooth it down
Step 7:
Step 8: Step 6:X-carve
After plaining one side put the board on the x-carve and smooth out both sides
Step 9: Step 7: Measure and Cut Corners
After the board is smooth measure what you want to cut off your edges then cut them off and then sand down smooth
Step 10: Step 8: Router the Edges
After corners are cut and sanded run the board through the router and carve the board
Step 11: Step 9: Final Sanding
Final sand with a high grit sandpaper to make board smooth
Step 12: Step 10: Laser Engrave
Find image and email to mr.b then run it through the engraver
Step 13: Step 11: Oil Board
After final sanding and board is engraved oil board
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
