DISPLAY HUMIDITY AND TEMPERATURE ON LCD WITH ARDUINO NANO
1,691
About: I'm a student of Uva Wellassa university Of Sri lanka. studying Mechatronics under Faculty of science and technology.
The following Instructable deals with making a simple lcd interface with arduino nano.
Teacher Notes
Step 1: Requirements:
    Requirements
    1. DTH11 Humidity and Temperature Sensor
    2. Arduino Nano
    3. 16*2 LCD display
    4. I2C module
    5. Connecting wires
    And
    • Arduino IDE
    • Arduino libraries
    I2c library(LiquidCrystal_I2C)
    DHT library(DHT.h)
    Step 2: Connect Components to Nano
    Connect components to nano as the screen shot,
    DTH11 To Arduino Nano
    Vcc --> 3.3V
    GND --> GND
    Out --> D4 I2C
    Lcd to Nano
    GND -->GnD
    SDA --> A4
    SCL --> A5
    Vcc -->5V
    Step 3: Include Libraries
    Download and include Below libraries,
    DHT sensor library(DHT.h)
    I2c library(LiquidCrystal_I2C.h)
    Include as above image.
    Go to ketch--> Include Library --> Add Zip File and then browse the folder,
    Close the IDE and open it again,
    You can download libraries from below links also,
    https://bitbucket.org/fmalpartida/new-liquidcrysta...
    https://codeload.github.com/adafruit/DHT-sensor-li...
    Step 4: Scan the I2C and Find the Address
    Download the I2C scanner and find your i2c address and then enter it to the code;
    You can find the scanner code from here also.
    http://www.mediafire.com/file/f7oaa4et779yaaz/i2c_...
    Step 5: The CODE
    //Compile and upload the code to arduino nano
    #include "DHT.h"
    #define SensorPin 4 // connect the out pin of dht sensor to D4 pin of arduino nano
    #define Dht DHT11
    DHT dht(SensorPin, Dht);
    #include<Wire.h>
    #include<LiquidCrystal_I2C.h>
    LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); //set I2C Address as 0x3F
    void setup() {
    Serial.begin(9600);
    lcd.begin(16,2);
    Serial.println("Temperature and Humidity Inteface");
    dht.begin();
    void loop() {
    int hum = dht.readHumidity();
    int temp = dht.readTemperature();
    lcd.setCursor(0, 0);
    lcd.print("Temp: ");
    lcd.print(temp);
    lcd.print("C");
    lcd.setCursor(0,1);
    lcd.print("Humidity: ");
    lcd.print(hum);
    lcd.print("%");
    Serial.print("\nCurrent Temperature: ");
    Serial.print(temp);
    Serial.print("C");
    Serial.print("\nCurrent Humidity: ");
    Serial.print(hum);
    Serial.print("%");
    delay(2500);
    Results are shown with above photos.
    Thanks,
    Dush.
    1 Person Made This Project!
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    2 Discussions
    Great Arduino project. You should enter this into the Microcontroller contest that is currently running.
