DIY 2020 Extrusion Corner Plates
About: Makers Mashup's mission is to free your inner maker by combining multiple maker skill areas into one place. Our weekly YouTube videos give you the tools to create your own mashups along with tips, reviews a...
If you're looking for some cheap aluminum corner brackets for 2020 extrusion look no further. This guidecovers how to create your own using some everyday 1/8" thick 2.5" wide rectangle bar. You can make about 10 of these for $6. These run $14 on Amazon for 4, so you're saving a ton of money by making these yourself. They work just as well. If you're building a 3D Printer this part can save a lot of money and add some strength to your printer build.
Supplies:
1. A Template. Either use an existing bracket like I did or you can use this DXF Bracket Template I created. This can be printed, or cut out from hardboard on a laser cutter. Printing it on some cardstock and cutting it out is very easy.
2. Some 1/8" thick aluminum bar stock. 2.5" wide. Available at most big box stores.
3. One 5mm Metric drill bit. Also available at your local big box store. or I have used these Metric Bits on amazon
4. Metal cutting saw blade. I used this Metal Blade from amazon
4. Sanding/Polishing wheel (Optional) to brighten up your part.
You will also need a miter saw to do the cutting and a drill press or drill to put in the holes.
Teacher Notes
Step 1: Step 1: Trace Your Template
Trace your template either the original or from the template you made from the DXF file. I used a mechanical pencil as it makes a very accurate line.
Step 2: Step 2: Cut Out Part
Cut out the part. Be very careful as cutting aluminum sometimes results in hot shards of metal flying around. Always wear eye protection and observe saw safety cutting it out.
Step 3: Step 3: Drill the Holes
Drill out the 5mm holes so you can mount this to your 2020 extrusion. Make sure you observe drill safety and wear protective eye gear.
Step 4: Step 4: Admire Your Work!
You can admire your work or optionally take the time to sand and polish up these brackets. You can see it looks (and works) just like the more expensive original.
Metal Contest
This is an entry in the
Metal Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    Penolopy Bulnick
    4 weeks ago
    Nice job on your first Instructable and welcome to the community :)
