DIY ARDUINO BLUETOOTH CONTROLLED CAR :)
2,157
21
5
About: LOVE PROGRAMMING
Hello, Guys! In this instructable tutorial, I'm going to make an Arduino nano based smartphone (Bluetooth) controlled car. All we know that Arduino is an excellent prototyping platform, principally because it uses a friendly programming language and there are a lot of extra incredible components that provide us great experiences. We can integrate the Arduino with different shields or modules and build fantastic projects. In this project i will show you how use the Bluetooth module to control a car through commands coming from a smartphone. So This car could be controlled via Bluetooth using any Android phone or tablets. This is an very interesting project. It's simple to make, easy to program the arduino and also a great project for all diy lovers like me. So don't waste your time and let's make this cool project with me.
Here's The Full Tutorial And Demonstration video :
Supplies:
Step 1: The Parts List :
Here's The Parts List:
1. Arduino Nano
2. L293D Motor Driver
3. HC05 Bluetooth Module
4. 18650 Li-ion Battery(2ps)
5. Old RC Car model frame
6. Male To Female And Female To Female Jumper.
7. Wheels(4ps)
8.Slide switch(1ps)
9. connecting wires
Step 2: Wiring Diagram/Circuit Diagram:
Here's the entire circuit diagram: click for circuit diagram
Step 3: Connect All the Modules & Soldering Wires:
First, we'll start off by connection the wheels into the model then soldering the motors then making the connection among all the modules.
At first, connect jumpers between motor driver and Arduino as follows .
D5>IN1
D6>IN2
D10>IN3
D11>IN4
Vin>5V OUT
GND>GND
Now Connect Bluetooth Module to Arduino And Motor Driver
Arduino --> Bluetooth Module :
TX>RX
RX>TX
Motor Driver --> Bluetooth Module:
5V OUT>5V IN
GND>GND
Now solder battery's positive wire to switch, then connect it to the motor driver and connect negative wire of the battery to GND of the motor driver.
Step 4: Mounting All the Modules:
Now it's time to mount all the modules. First, apply some hot glue mount motor driver. Next, we'll mount Arduino and BT module. Then mount the battery. After mounting all the modules connect front and rear motor wires to the motor driver according to the circuit diagram.
Step 5: Upload the Code:
First, remove your bluetooth module then connect the Arduino to your pc, then upload the code.
link of the code:CLICK HERE FOR THE CODE
Step 6: Download the App & Connect to the Car :
Download the car controller app from google play store.
The app link: click here for app
Now Pair your Arduino Car to your Mobile phone in bluetooth setting on your phone
Open Aruino app Click 'Connect' button Select 'HC-05' or any name you set for your HC-05 .and finally Let's play with your own made car :) :)
Step 7: We're Done Now:
Finally, we're done now. Have fun with this Arduino smartphone controlled car.
If you need the video tutorial then here's The Full Tutorial And Demonstration video:
I hope you'll like it. Don't forget to follow me for my upcoming awesome projects .Thank you and all the best .keep smiling and keep learning :)
Arduino Contest 2019
This is an entry in the
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    5 Discussions
    In would like to do this for a school engineering project if that is ok with you, if so would you suggest any type of RC model frame?
    BibroBamw0107smb1227
    Answer 9 days ago
    Yeah sure. Actually I use a old rc car's model frame .you can use same or you make the frame by own using acrylic sheets. Okey as soon as possible, I shall try to make another instructables to show you that "how to make the model frame " . thanks.
    sumitsharma0698BibroB
    Reply 4 days ago
    When will you be going to make that eagerly waiting for that
    WeTeachThemSTEM
    18 days ago
    Looks like you had fun putting this car together! I love the rooftop photos. :D Thanks for sharing!
    BibroBWeTeachThemSTEM
    Reply 18 days ago
    Thanks mam . Thanks for your lovely comments. I really enjoy my every projects ,and your that kind of comments give me more motivation for enjoying more fun .
