DIY || Blowable Electric Candle
Introduction: DIY || Blowable Electric Candle
Blowable Electric Candle is a candle which can be blown off and can reglow after sometime. The time after which it will reglow can be adjusted (by varying the capacitance).
This project is based on Transient clap switch circuit which is a circuit which turns ON the load (light) when it detects clap/blow. For this candle, the output effect of the circuit is reversed (using Relay) i.e. now the light turns OFF when it senses blow/clap.
Teacher Notes
Step 1: Materials Required
To make this project, we require:
• Relay (6V)
• Condenser Microphone
• Transistors – BC 547 (2)
• Resistors – 330 Ω, 10 K Ω (2), 1 M Ω
• Capacitor – 4.7 μF
• Switch
• LED
• Battery (9V) and Battery Clip
• Wires
• PCB
• Cardboard
• Paper
Major Tools required:
• Soldering Iron and Solder Wire
• Hot Glue Gun
Step 2: Circuit Diagram
This circuit is basically Transient Clap Switch Circuit
Step 3: Controlling Re-glow Time
You can refer these values to control the time for which the LED will be blown OFF.
Step 4: Step-by-step Tutorial
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
