DIY Bluetooth Modification Sony MDR-7506 Headphone
3,447
28
4
Introduction: DIY Bluetooth Modification Sony MDR-7506 Headphone
This post about convert famous headphone Sony MDR-7506 and its fake copies to DIY Bluetooth modification.
I had headphone Sony MDR with very great sound and comfortable design. And also quite thick cable is with it. That was well when I used one on my office. Use it during walk to home or job difficult, because cable dangle, pulled down, tangled in clothing. That actually annoyed me. Therefore, I decided to detach cable and convert headphone to Bluetooth version.
Currently there are many BT modules fit for sound DIY project. Some of ones support APT-X. I chose stereo CSR8645 module with amplifier board. Module also support microphone and I add this feature to MDR BT mod.
Teacher Notes
Step 1: Parts
Here is part list:
- Bluetooth 4.0 CSR8645 module with amplifier board
- Charge LiPo battery module TP4056
- LiPo battery LP602030 overall dimensions 6х20х30 mm
- microphone ECM-10C diameter 6 mm
- tact push button high 9.5 mm (KLS7-TS6601-9.5-180) – 5 pieces
- mini slide switch appropriated size
- some tools and materials…
Step 2: Modelling
First I disassembled left and right ear cups and measure inside dimensions, then each of ones was created 3d models. Also I did it for other parts of set. Then I spent some time try to assemble and after few attempts I had acceptable result. All models you can find here – https://grabcad.com/delirium-1/models
I developed two kind of circuit board for right and left ear cup to place parts. Bluetooth module with buttons are soldered on custom circuit board and putting in left ear cup. Before it i drill holes for buttons and extended former hole for cable until diameter 6.5 mm then inserted microphone in it then soldered to circuit board too.
Charge module TP4056 and slide switch are placed on circuit board inside right ear cup. There is LiPo battery there too. Also i must cut two slot on a side ear cup. One for switch and another for micro usb charged cable. Dimensions right circuit board is on picture (previous design board with sensor switch, but it has same size as new).
Step 3: Make Circuit Boards
Then I made circuit boards.I used male pin header to solder parts on boards and
then cropped they a little to make "sandwich" less thick.
Here is ready Bluetooth board assembly.
Step 4: Test and Mount
First time test.. great, it’s working! Module pair to phone easily and sounds well. Assembly boards is ready to placed into ear cups. I used melt plastic gun to fix they.
Step 5: Finish
At the end, I replaced original cable (two wires) between earpiece by usb cable (four wires) to connect sound and power line. I obtained quite similar on previous result. DIY BT mod MDR-7506 headset done.
Left ear cup. I drilled hole diameter 1.5 mm for amplifier red led that indicate work headset, and dripped a little melt plastic.
Right ear cup. Red led is bright if charge on. When charge full blue led is bright.
Step 6: Result
Here is view on microphone and buttons. Unfortunately,
I worked dremel carelessly… However, that doesn't matter, because ultimate result is pretty well.
Step 7: The End
Thanks for your attention!
And warning! If you want to make same with you Sony MDR-7506 you will most definitely void any warranty you might have for your headphones. You might also damage your headphones if you are not careful, so please do not accuse me!
If you need more information such as electrical schemes, print circuit boards, some explanations, etc, contact me.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    4 Discussions
    sarahvo
    sarahvo
    Question 11 months ago on Introduction
    Hi skatech! I am very impressed with the finishing of your project and I'm planning to do it by myself! But this removes the audio jack right?
    skatech
    skatech
    Answer 11 months ago
    HI! Yes, the jack was completely removed, and a microphone was inserted into its hole. Only wireless connection now.
    jessyratfink
    jessyratfink
    1 year ago
    This is a great mod! This finished headphones look nice and clean. :)
    skatech
    skatech
    Reply 1 year ago
    Thank you!
