DIY Bluetooth Speaker
Introduction: DIY Bluetooth Speaker
In this project, I made a Bluetooth speaker with a speaker that I do not use at home.
Teacher Notes
Step 1: Measurement
Measure and record the dimensions of the parts.
Parts & Products Used
1. TP4056 : Battery Charger
2. XY-BT-L : Bluetooth Speaker module
3. Lithium Battery : 1300mha
4. Push Button
5. MDF 3t
Step 2: Soldering
The schematic is very simple
After connecting the circuit, check if the Bluetooth power is well received.
Step 3: Modeling (AutoCAD)
I used AutoCAD program to place each part and complete the design.
Step 4: Laser Cutting
We will make a case using a laser cutting machine.
The material used 3t mdf.
Step 5: Assembly
let's assemble
Since the button is down, I will insert the part where the button is pushed through the long bar.
Step 6: Complete
Thank you :)
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    seamster
    seamster
    6 weeks ago
    This looks great. Nice results! : )
