DIY Bubble Fountain
1,787
25
About: FUN DIY, CRAFTS, EXPERIENCE THE JOY OF DOING IT YOURSELF. OFFICIAL CHANNEL. RusticKraft is a channel provides articles, tutorials, creative ideas. Our audiences are from all around the world. Hope our videos...
Materials Needed:
  • Acrylic Sheet
  • Air Pump
  • Aquarium Pipe
  • Blue Waterproof LED
  • LED Adapter
  • Wood
  • Black Tape
  • Spray Colour
  • Hot Glue
  • Super Glue
  • Silicon Sealant
Tools Needed:
  • Cutter
  • Needle
  • Drill
Teacher Notes
Step 1: LED and Piping
So Let's start...
  • We need 2 Acrylic sheet of 23cm height and 2cm width.
  • Attach Waterproof LED on 1 sheet.
  • Take an aquarium pipe and seal one end with hot glue.
  • Then place the pipe on that sheet with hot glue.
  • Take a needle and make some holes on the pipe.
  • Then take a drill and make a hole on the other pc of the acrylic sheet
Watch the full video on YouTube and don't forget to SUBSCRIBE and SHARE
Step 2: Colouring the Sheets
Then we need 2 more Acrylic sheets of 13.5cm height and 2cm width.
  • Take the drill and make a hole on 1 sheet, so the pipe passes through.
  • Make 1 more small hole just below the last hole, so the electric wire of LED passes through.
  • Now colour the 4 acrylic sheets with Black spray colour.
Step 3: Assembling
Now we need an Acrylic sheet of 18cm height and 25.5cm width.
  • Attach black tape on the sheet.
  • Then turn the sheet and put silicon sealant.
  • Take the 4 pcs of acrylic sheets and place them.
Step 4: Final Sheet
Then we need an Acrylic sheet of 14cm height and 23cm width.
  • Colour the sheet with Black spray colour.
  • Put silicon sealant on the top of the 4 sheets and place this sheet on it, and let it dry for 24 hrs.
Step 5: Electrical Connection
  • Now take a wood and give a 2.5cm cut and place the structure on it.
  • Connect the LED Adapter with the LED.
  • Then take an Air pump and connect with the pipe.
Step 6: Final
  • Switch on the LED and the pump
  • Finally, fill the structure with water and enjoy the Bubble Fountain.
Plastics Contest
Plastics Contest
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
