DIY || Clap Counter From Calculator
Here, I am going to show you how to make a ‘Clap Counter’ from a Calculator.
In Clap Counter, every time a clap is made, a count is recorded.
*You can re-use the calculator for normal functioning.*
This project is based on Transient Clap Switch Circuit which is rendered to count the claps.
Teacher Notes
Step 1: Circuit Diagram
This circuit is basically Transient Clap Switch Circuit.
Step 2: Materials Required
To make this project, we require :
• Calculator
• 555 Timer IC
• BC 547 (2)
• Relay (6V)
• Condenser Microphone
• Resistors - 1K Ω, 47K Ω, 100K Ω
• Capacitor - 1 μF
• Diode - 1N4007
• Switch
• Battery and Battery Clips
• PCB • Cardboard
• Wires
Major Tools required:
• Hot Glue Gun
• Soldering Iron and Solder Wire
Step 3: Step-by-step Tutorial
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
