DIY Color Block Crop Top Sweatshirt & Sweatpants (Beginners Sewing)
Introduction: DIY Color Block Crop Top Sweatshirt & Sweatpants (Beginners Sewing)
About: Making things, going places, doing stuff. Join me :) Contact: mgjmedia@gmail.com
You just can't beat a comfortable pair of sweats, and this project is the perfect combination of cute and comfortable. Here's how to turn basic sweatshirts and sweatpants into a dynamic color block crop top and pants set with some simple sewing! Plus, you can actually get two outfits out of this.
Step 1: Gather Materials
What you'll need:
Miaira is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to Amazon.com.
Step 2: Cut Sweatpants
Place the pairs of sweatpants on top of one another, making sure everything is lined up neatly. Then fold them in half vertically, trace the angled line and cut along the line through all layers (make sure your scissors are sharp!).
Step 3: Pin the Pieces
Flip everything inside out and assemble the colors the way you like. Then pin along the cut edges of the top layers, making sure not to pin the bottom layers (so you don't accidentally sew the pant legs shut).
Flip the pants over and pin the other side.
Step 4: Sew Pants Pieces
Sew along the pinned edges, removing the pins as you go. Again, make sure the layers aren't stuck together so you don't sew the pant legs shut!
Step 5: Cut Sleeves
Now that the pants are done, complete the same process with the sweatshirt. Layer the sweatshirts on top of each other and fold in half vertically. Then trace the angled line and cut along the line through all sleeve layers.
Step 6: Crop Bottom
Unfold everything and trace the line at the bottom of the sweatshirt where you'd like to cut to create the crop top. Then cut along the line. You can also just leave it full length, if you'd like.
Step 7: Pin Sleeves & Bottom
Flip everything inside out and carefully pin the sleeves together along the cut edges. Then fold the bottom edge over about an inch and pin it in place. This will be the casing for the elastic cord to cinch the waist.
Step 8: Sew Sleeves & Bottom
Sew along the pinned edges and the cropped bottom.
Step 9: Add Elastic Cord
Once everything is sewn, cut a very small hole at the bottom on the top layer. Attach a safety pin to the end of a piece of elastic cord (measured to fit around your waist). Then slip the safety pin through the hole and work it all the way around to the other side.
Step 10: Add Fastener Button
Keep the elastic in place by attaching the elastic fastener button and securing it with a knot.
Step 11: All Done!
That's everything! With a little cutting and mixing, you now have a stylish color block sweatshirt and sweatpants set. :)
Full video tutorial:
Instagram: https://www.instagram.com/miairajennings/
YouTube: https://www.youtube.com/miairajenningstv
Blog: https://livegrowglow.com
Website: http://miaira-jennings.com
Pinterest: https://www.pinterest.com/miairajennings/
Business Inquiries: MGJmedia@gmail.com
Shop my Amazon store: https://www.amazon.com/shop/miairajenningstv
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
