DIY Compost Recycling Bin
1,618
31
7
Introduction: DIY Compost Recycling Bin
About: I'm a student product designer and tinkerer who loves to create. My focus is on designing things that can be both fun and accessible.
I wanted a compost bin but there were no cheap options in my area so I decided to make my own. I have been using it for about a month now and found that adding some soil to the mix helps with the breakdown process. The soil had the added bonus of having some worms so now I have them in there bringing some composting muscle to the process.
Purchase a plastic bin with a lid that can be secured. Mine cost around $20.
Why a secure lid?
You're going to need to shake the bin to mix the compost up around once a week. Having a secure lid means you can roll it along the ground when it gets heavy or if you don't like compost juice dripping on your feet!
The lid also means the neighbors dog (pictured below) can't get in.
Supplies:
1 Bin with a lid that can be secured
Drill and drill bit
Garden waste such as dried leaves, grass clippings and wood chips
Kitchen waste
Newspaper (optional)
Rocks or bricks for the bin to stand on
Gardening gloves
Step 1: Drill Holes
  1. If you're an artist now is your time to shine, decorate your bin before you drill the holes.
  2. Using the biggest drill bit you have, drill holes in the base of the bin. If you have a small drill bit, drill more holes.
  3. Drill holes in the side of the bin. You can choose to add more or less than I did.
Why so many holes?
They help aerate the compost. To help the compost cook, you need a mix of heat, moisture, and oxygen in your bin so that bacteria and microorganisms can do their job.
Step 2: Add the Compost
So you don't end up with a smelly gooey mess you need a mix of brown fibrous material (garden waste) and greens (kitchen scraps).
  • Add a base of garden waste.
For example leaves, dried grass clippings, fallen branches (broken up into smaller pieces), wood chips, shredded paper.
  • Add kitchen waste.
  • Add soil if you have some.
Step 3: Shake Shake Shake
Hooray your compost bin is ready!!
  • Give yourself a pat on the back, you just saved $$, rubbish from landfill and started making your garden the plant equivalent of superfoods.
  • Give your bin a big shake to get everything to mix together.
Step 4: Lift Off
Put your compost on either some bricks or rocks so the air can get underneath it.
Step 5: Composting Tips
Compost waste dos and don'ts
Do add: vegetable scraps, fruit scraps, coffee grounds, eggshells, leftovers, loose leaf tea, bread, tomato sauce, pasta, stale cereal, cut up cardboard egg cartons, dairy such as yogurt (in small amounts), pencil shavings, shredded paper, farm animal manure, hay, cold fireplace ash.
Don't add: Meat, fish, kitchen fats, citrus peel (kills your helpful worms), tea bags (most aren't 100% organic), disposable coffeecups, glossy paper, coal and charcoal-briquet ash, dog or cat poo, anything non-organic, anything with chemicals on or in.
Other tips:
  • keep your compost in the shade if you live in a hot climate.
  • shake or tumble your compost about once a week to mix everything through.
  • add a mix of waste. If your bin is getting smelly you need to add more dry brown waste such as dried leaves.
  • be patient.
Backyard Contest
Backyard Contest
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Bikes Challenge
      Bikes Challenge
    7 Discussions
    better_babs
    better_babs
    1 year ago on Step 5
    I haven't ever started a compost but am wanting to try this but one question, how will I know if it's ready?
    Silvia Henderson
    Silvia Henderson
    Reply 1 year ago
    it takes a while to break down, but you will see the pile go down, and it will have an earthy smell. I try it on a bucket, but did not put holes in it, well I have a brown smelly mess now lol, so I need to add more browns and air!
    kupua
    kupua
    Question 1 year ago on Step 5
    How the heck are you supposed to harvest the compost/castings when ready?
    Silvia Henderson
    Silvia Henderson
    Answer 1 year ago
    this is a compost! did you wanted a vermicompost? then you need to get red wigglers, its a whole different set up and maintenance
    livingdanishly
    livingdanishly
    Answer 1 year ago
    If you’re lucky enough to have a two bin system you shovel the top stuff that hasn’t broken down into the second bin otherwise into another container to expose the good stuff beneath. Once you’ve tipped that out you put the top stuff back in and keep the process going.
    maminurrashids
    maminurrashids
    1 year ago
    How long to wait the composting to be ready to use?
    seamster
    seamster
    1 year ago
    Very good info, thank you!
