DIY Cropped Hoodie
About: Canada's #1 source for online custom designed t-shirts. Head to our website to design your tee now! #jointheherd
A relatively simple clothing mod to enhance any hoodie.
Supplies:
  • Old Hoodie
  • Ruler
  • Scissors
  • Tape/Pencil
Teacher Notes
Step 1: Create Your Guide
Use a ruler to make a straight line just above the pocket.
Create the guide-line using tape or a pencil.
If using tape, put one piece of the tape under the line on one side and above the line on the other as seen above.
Note: using tape leaves a clean line so you don’t have to worry about marks on your sweater afterward.
Step 2: Cut
Cut across the line that you made.
Don’t worry if the cut isn’t clean, you can make adjustments after you have made your main cut (or not if you prefer a more unfinished look).
Step 3: Finished
You are done! Enjoy your new Crop Hoodie!
If you want to see this project in action check out the video.
If you need a Custom Hoodie for your project then click the link!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
