DIY Easy Shelves | Industrial
Introduction: DIY Easy Shelves | Industrial
A very easy construction that can be made with a few and cheap materials. You can adapt it to whatever dimension you need, also you can paint the shelves and legs as you wish for a more personal result and a piece of furniture that fits your space!
Teacher Notes
Step 1: Shelves
I bought three wood boards in the dimensions I needed, and with the help of a drill I made four (13mm) holes in the corners of every board. In this step you can paint the shelves or you can leave them the way they are, it's clearly up to you.
Step 2: The Legs
To support the shelves I use:
x4 Threaded Rods (1m length)
x24 M12 Hexagon Nuts
x24 M12 Washers
x4 Long Hexagon Nuts
All the above I painted with copper metallic spray paint, You can leave them with their original color or paint whatever you want.
Step 3: Assembly
What we have left is to assemble them all together. It's pretty easy because all we do is to put the threaded rods in the holes of every corner on the wooden board and secure them with a washer and a nut at the top and bottom. And for the end, we're just screwing the long hexagon nuts at the bottom of the legs, so to be able to regulate the level of the furniture.
Shelving Contest
This is an entry in the
Shelving Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Kink Jarfold
    Kink Jarfold
    23 days ago on Step 3
    That is so efficient and it looks great.
    illustrisWorkshop
    illustrisWorkshop
    Reply 8 days ago
    Thank you! Yes, it so efficient and so easy to build!
