How to Make a Fabric Hanging Room Divider?
Hanging room divider is both good privacy protection room separator and decorative partition. It is a good choice to fully develop your limited interior space. How to make a hanging room divider if you plan to make it of your own favor and style. Let's make hanging fabric room divier as example for the simple operation.
Preparation:
Plan and measure the size of the fabric hanging room divider (for example, measuring the ceiling space or bracket placement where you are going to hang the room partition), making the proper size of the fabric (length and width);
Choose the fabrics or curtains you like (find the proper pattern and color);
DIY Hanging Room Divider:
Lay your drop cloth on the floor and cut the fabrics into certain size as measuring before;
Sew the top line of the fabrics so than you can put a sling through the line to fixed the divider or fix the hooks arranged on the ceiling or bracket to hanging it or lay the plywood sheet on the top of the cloth, and then drill a hole at least 1/2 inch in diameter once the sheet is dry, closely attached fabrics and sheet.
Teacher Notes
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
