DIY Firecracker Banner
Introduction: DIY Firecracker Banner
About: I'm a harpist who enjoys DIYing. ☺ DIY/Lifstyle(ish) - IG, FB: @thefischlife Harp - IG, Twitter, FB: @fischarperjr
Make a fun firecracker banner for your next 4th of July event or photo booth!
If you'd like to watch a highlight video of the project, visit The Fisch Life IGTV channel.
How would you use it? Show me on Instagram at @TheFischLife & don't forget to tag @Instructables too.
Supplies:
  • empty toilet paper tubes
  • red paint
  • white paint
  • blue paint
  • scrap paper
  • yarn (or twine, or whatever you'd like to use for the "fuses" & string)
  • paintbrushes
  • glue
Step 1: Paint
Paint the toilet paper tubes red, white, & blue.
Allow to dry.
Step 2: Tops
Paint the scrap paper the color of the tubes (optional).
Allow to dry.
Cut or punch a hole in the center & glue onto the top of each tube. (I'd recommend cutting them into smaller pieces, a bit bigger than the tube openings before making the holes).
*I recommend adding the "fuse" before gluing this paper on. (See the next step.)
Once dry, cut the paper around the tube.
Step 3: "Fuse" & Tissue Paper
Cut approx. 7" lengths of your "fuse" material. Make enough for the number of "firecrackers" you're making.
Loop & tie each, then place through the paper hole.
*Recommendation: do this before you glue on the paper. If you do it after, just use some small scissors or something to help poke it in.
Next, cut small-ish pieces of matching tissue paper & adhere over the paper using glue & a paintbrush or your finger. Allow some overhang. Paint over the tissue paper with a thin layer of glue.
Step 4: Trim, Glue
Trim the tissue paper edge to a rough circle, leaving some extra.
Glue around the edges & smooth down, gluing over that as well. You can use a paintbrush or your finger for this as well.
Allow to dry.
Step 5: Glue, Trim, Glue
Cut a piece of tissue paper a bit bigger than the bottom opening of the tube.
Spread glue around the ring of the tube & place the tube on the tissue paper. Adjust as necessary.
Trim around the circumference & glue around the edge like you did with the top.
Cut a long length of the material you used for your "fuses." Loop & arrange the "firecrackers" as you like & display your banner!
Paint Challenge
Paint Challenge
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
