DIY Fountain With Acrylic Sheet
2,783
34
Introduction: DIY Fountain With Acrylic Sheet
About: FUN DIY, CRAFTS, EXPERIENCE THE JOY OF DOING IT YOURSELF. OFFICIAL CHANNEL. RusticKraft is a channel provides articles, tutorials, creative ideas. Our audiences are from all around the world. Hope our videos...
Materials Needed:
  • 3mm Acrylic Sheet
  • 3W Water Pump (200L/Hour)
  • Waterproof LED
  • 12 Volt LED Adopter
  • 3/4 inch Pipe
  • Masking Tape
  • Push Terminal
  • Plug
  • Electric Wire
  • Bucket
Tools Needed:
  • Silicone Sealant
  • Super Glue
  • Hot Glue
  • Epoxy Resin
  • Soldering Iron
  • Drill
  • Scissor
  • X-Acto Knife
  • Cutter
Decorative Items:
  • Plastic Plant
  • Spray Colour
  • Paper Sticker
Teacher Notes
Step 1: Squaring Up the Acrylic Sheet
Let’s start with 4 pcs of 3mm Acrylic Sheet of 18” x 4” and 6 small pieces of ½” x 3” for the bracing.
  • Place 4pc (18”) pcs side by side and make a rectangle with masking tape. (Refer images)
  • Attach the 4 small acrylic pieces with super glue on top of every 18-inch acrylic pieces.
  • Another 2 small acrylic pieces at the bottom of 2nd and 4th 18-inch acrylic pieces.
  • Then fold the 18-inch acrylic sheets and stick them with the masking tape.
Watch the full video on YouTube:
Step 2: The Piping
Now we need an acrylic sheet of 3" x 3.8" (Sheet 1)
  • Make a hole at one corner of the acrylic sheet to attach the water pump. (Refer Images)
  • Take a 3/4" make a small cut, insert an electric wire through the pipe, and seal with epoxy
  • Attach the long pipe with an electric wire in it at a corner with silicone sealant and dry it out.
Step 3: Preparation for the Waterfall
Use an acrylic sheet of 3.8”x 3.8”(Sheet 2) with a small notch at a corner for the pipe to pass.
  • Attach the sheet with Silicon Sealant on the 4 small acrylic sheets which were placed in the body of long square acrylic sheets on top.
  • Then, with a soldering iron make few small holes on the sheet, to form rainwater drops.
Step 4: Electric Connection
Now we need an acrylic sheet of 4"x 4 (Sheet 3).
  • Cut the Blue Led into 4 small pieces.
  • Take 2 LED pieces, make a parallel connection, and attach them on the acrylic sheet 3.
  • Turn the sheet and spray with a silver color. (optional)
  • Take a Push Terminal and make a connection with the LEDs and the electric wire.
  • Attach the sheet 3 with Silicon Sealant on top of 18" long square acrylic sheets and let it dry for a couple of hours.
Step 5: Water Pump Connection
Now take the acrylic sheet of 3" x 3.8". (Sheet 1)
  • Attach the Water Pump with hot glue on the sheet 1.
  • Put a decorative item inside (here I used an artificial plant) the18" long square acrylic sheets.
  • Then attach the sheet 1 with super glue on the 2 small acrylic sheets which were placed in the body of long square acrylic sheets at the bottom.
  • Take 2 LED pieces, make a parallel connection and attach them on sheet 1.
  • Connect the LEDs with the pump and electric wire together and connect them with a Push Terminal.
  • Then take a 12 Volt LED Adopter and connect it with the same Push Terminal.
Step 6: Final Setup
  • Use the paper sticker to cover the masking tape area.
  • Take a bucket for water container and spray with a silver colour (optional)
  • Cut the lid of the bucket and place the long acrylic sheets on the bucket.
  • Then finally plug in the wire connected with the 12 Volt LED Adopter and switch it on.
Plastics Contest
Plastics Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    2 Discussions
    That looks really nice. If you get a chance, if you could add titles to each of your steps it would make it easier for readers to scroll between sections of your project.
    Rustickraft
    Rustickraft
    Reply 1 year ago
    Thanks for the suggestion, I will surely do that.
