DIY HOME AUTOMATION - Replace Traditional Light Switches
Turn on or off LIGHTS using touch sensors
Features:
  • Capacitive touch sensors are used to turn on the lights instead of traditional mechanical switches.
  • PIR Sensors for automated lights.
Teacher Notes
Step 1: Materials Needed
Step 2: LIGHTS- Selecting the Pins for Touch Sensors and Relays
Here 4 capacitive touch sensors are used. Each one is use to turn on or off the light.
How it works? When the sensor the pressed it activated a relay. The light connected to the relay is then activated. To turn off the light the sensor is pressed again.
______
Pin 22 - Touchsensor1
Pin 23 - Touchsensor2
Pin 24 - Touchsensor3
Pin 25 - Touchsensor4
______
Pin 26 - Input 1 of relay (Relay1)
Pin 27 - Input 2 of relay (Relay2)
Pin 28 - Input 3 of relay (Relay3)
Pin 29 - Input 4 of relay (Relay4)
______
Touchsensor1 activates Relay1 and so on...
Step 3: LIGHTS - Selecting Pins for PIR Sensors and Relay
There are two lights that are activated by the PIR sensors.
______
Pin 30 - PIR1
Pin 31 - PIR2
_______
Pin 32 - Input 5 of relay (Relay5)
Pin 33 - Input 6 of relay (Relay6)
_______
PIR1 activates Relay5
PIR2 activates Relay6
Step 4: Programming the Arduino
// Pins for capactitive touch sensor
#define TouchSensor1 22
#define TouchSensor2 23
#define TouchSensor3 24
#define TouchSensor4 25
// Pins for PIR sensors
int PIR1 = 30; //
int PIR2 = 31; //
int val1 = 0;
int val2 = 1;
boolean currentState1 = LOW;
boolean lastState1 = LOW;
boolean RelayState1 = LOW;
boolean currentState2 = LOW;
boolean lastState2 = LOW;
boolean RelayState2 = LOW;
boolean currentState3 = LOW;
boolean lastState3 = LOW;
boolean RelayState3 = LOW;
boolean currentState4 = LOW;
boolean lastState4 = LOW;
boolean RelayState4 = LOW;
// Pins for relay
int Relay1 = 26;
int Relay2 = 27;
int Relay3 = 28;
int Relay4 = 29;
int Relay5 = 32;
int Relay6 = 33;
void setup() {
//define relays as output
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
//define touch sensors as input
pinMode(TouchSensor1, INPUT);
pinMode(TouchSensor2, INPUT);
pinMode(TouchSensor3, INPUT);
pinMode(TouchSensor4, INPUT);
THE FULL CODE IS AVAILABLE TO DOWNLOAD BELOW
CLICK ON THE FILE X.ino to download.
Step 5: CIrcuit Diagram - Wiring Light to Relay
This picture is self- explanatory.
Beware risk of electric shock
Be the First to Share
    • Assistive Tech Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    8 Discussions
    KayaO2
    10 months ago on Step 5
    Great idea, interested in it myself as doing home renovation. Few questions:
    How to cover the touch sensors? Plaster over?
    How to connect it and control it with another smart home system to unify with Zigbee / Z-wave supporting system?
    I guess once connected to a smart home system, can also work with Alexa / Siri / Google, or any other way?
    Akshay KoonjaKayaO2
    Reply 10 months ago
    You can use silicon paste to cover it or mold a casing for the sensor
    I don't know about zigbee but if the arduino can be connected to wifi maybe it might work with Alexa,etc
    gth-au
    10 months ago
    I've been mulling over something similar to this for a while now. This looks nicely done.
    This approach has lots of benefits that can be taken advantage of - like having two switches for one light (wiring diagram?).
    Do you have any photos of the final appearance of the touch sensitive pads? I'm curious how they look.
    Akshay Koonjagth-au
    Reply 10 months ago
    thanks.. two switches can be used as a 2 - way switch.
    this is only part of a bulky project so i don't have any pictures to illustrate this one.
