DIY Hour Glass Water Feature
About: FUN DIY, CRAFTS, EXPERIENCE THE JOY OF DOING IT YOURSELF. OFFICIAL CHANNEL. RusticKraft is a channel provides articles, tutorials, creative ideas. Our audiences are from all around the world. Hope our videos...
This DIY Hour Glass Water Feature in your terrace garden will gleam up the beauty of
nature.
Materials needed for the project:
  • Plastic Tray
  • Plastic Pots
  • Plastic Pipe
  • Foamboard
  • PVC Pipe
  • PVC L-Joints*2
  • 3W Submersible Water Pump
  • 5V Adapter
  • Nuts*2
  • Plastic nozzle
  • Magnet
  • Metal String
  • Drill
  • Super Glue
  • Hot Glue
  • Artificial Plants
Teacher Notes
Step 1: Hourglass With the Pots
Lets Start...
To build the hourglass feature I got two plastic pots
Give a cut on the top the pots as shown in the imgs.
Take two circles pcs of foamboard and join them together with super glue.
Give a cut on the middle of the circle and attach them at the bottom of the pot
Place a plastic pipe in the middle, so the pots can move easily.
Then attach the other pot with it as shown in the imgs.
Take 2 nuts and stick them on both ends of the pots. So the hourglass is ready.
Watch the full making on our YouTube Channel:
Step 2: Stand to Hold
Now we need to make a stand to hold it.
To make the stand take 3 pcs of PVC pipe and 2 pcs of PVC L-Joints
Make a hole with the drill in the middle of all the PVC pipes
Now take a plastic nozzle and attach it on the top PVC pipe
Take a plastic pipe and pass it through an L-Joint
Join the PVC pipes with the L-joints and the stand is ready.
Step 3: The Base
Now we need a base to store the water, so I got this plastic tray
Take a pc of wood make a hole with the drill on both ends and place it on the tray
Join the PVC stand with the wood holes.
Step 4: Final Assembling
Now take the plastic pots and pass a Metal String through the small pipe on the middle of the two pots
Then hang it by tying the metal string with the PVC pipes.
Take a 3W Submersible Water Pump and connect it with the plastic pipe which is connected to the top PVC pipe. Connect the pump with a 5V Adapter.
Stick a magnet in the wood just under the nut, to stop the pot when it will rotate down.
Now its ready to play.
Fill the tray with water and switch on the pump.
Enjoy the lovely Hour Glass Water Feature.
Thank You for the day... Bye till now.
Enjoy the full making on our YouTube Channel:
Check out more DIY Crafts made by RusticKraft Channel on YouTube and
don't forget to Share and Subscribe:youtube.com/rustickraftchannel
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
