DIY Humidifier
Introduction: DIY Humidifier
About: I'm a high school engineering student trying to make a mycelium-based bioplastic.
Do you need more humidity in a room? I built this humidifier to help keep my mushrooms happy, but this design would work for any of your humidity needs!
Supplies:
  • small watertight box (ex: baby wipes container)
  • bottle (with a diameter taking up less than half the top surface of your box
  • evaporating surface (preferably a humidifier filter, but a sponge also works)
  • electrical plug
  • small computer fan (with a diameter taking up less than half the top surface of your box)
  • electrical tape
  • 9-volt battery
  • battery to wire snaps
Teacher Notes
Step 1: Assemble Materials
Assemble the materials: fan, soda bottle, sponge, and watertight box with a lid
Step 2: Marking Up the Box's Lid
Trace out the cross-section of the soda bottle and the circular cross-section of the fan area that has air-flow
Step 3: Cut It Out
Cut out both cross-sectional areas with a jigsaw
Step 4: Electrical Work
Wire the computer fan to a plug
Step 5: Prepare the Bottle
Cut slots into the neck of the bottle, to allow water to escape when it is inverted.
Step 6: Check the Fit
Do a dry-assembly to check the fit
Step 7: Assemble the Elements
  1. Place the sponge in the box, under the fan-hole
  2. Fill the soda bottle with water
  3. Place the soda bottle in its hole
  4. Invert the lid and soda bottle over the box, allowing water to flow until it reaches equilibrium
  5. Place the computer fan over its hole
  6. Secure the Computer fan with screws
Step 8: Extra Advice
This is a very simplistic humidifier, and this instructable is ripe for modification.
The main issues with my humidifier were:
  • It very inefficiently gobbled energy for an un-regulable amount of time. In future versions, I highly recommend adding a timed switch-off feature and some regulator of electricity consumption.
  • Sponges make extremely mediocre evaporating surfaces. On one hand, they do facilitate evaporation. On the other hand, they are a breeding ground for bacteria and never dry out.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    Penolopy Bulnick
    Penolopy Bulnick
    9 days ago
    Humidifiers are so useful! Thanks for sharing :)
