DIY Hyperloop
Introduction: DIY Hyperloop
In this project, you will design engineer, build and test a vehicle that has been inspired by the Hyperloop concept. You won't be using maglev or linear motors to power your vehicle, and we won't be working at full scale! However, we are looking at the concept of a Hyperloop track that would run from Glasgow School of Art to the University of Glasgow - approx 1.6km. Since we are working at scale, passengers will be represented by fresh, uncooked hens’ eggs. We obviously don't want you to be cracked upon arrival!
Teacher Notes
Step 1: Components, Tools and Software
Test track
Approximately scale 1:28, a pipe which is 60m long, and has an internal diameter of approx 80mm
Carriage
EDF, LiPo, ESC, RC receiver and transmitter, electrical wire, soldering iron, solder, heat-shrink, pipe (optional), 3D printer, nuts, bolts, metal components (see diagram for eng drawings), servo, m6 threaded bolt, sponge, egg box, tape, EMA Plastic Weld Glue, Autodesk Fusion 360
https://hobbyking.com/en_us/edf55-with-h300-motor-...
https://hobbyking.com/en_us/hobby-king-30a-esc-3a-...
https://hobbyking.com/en_us/turnigy-nano-tech-850m...
https://hobbyking.com/en_us/jst-xh-2s-wire-extensi...
https://www.ebay.co.uk/itm/12-inch-Lengths-5mm-to-...
Passengers
2 British Standard Organic Medium Eggs
Step 2: Development and 3D Printing
After viewing (and possibly developing) the given Autodesk Fusion 360 CAD models print the following:
  1. head of main body
  2. braking mechanism
  3. joining couple
  4. centre of main body (a alternative would be milling a pipe of similar dimensions)
Step 3: Constructing the Foam Model
  1. hollow out and split sponge
  2. cut out the compartments of the egg box
  3. assemble with glue as shown above
  4. insert eggs
  5. tape together the sections
Step 4: Assembly
  1. assemble the braking mechanism (as instructed by the diagrams above)
  2. glue the EDF to the the head of the main body (as shown above)
  3. glue the rear to the main body (as shown above)
  4. glue the joining couple to both the head and centre of the main body
  5. solder and heat shrink the EDF to the ESC, ESC to the RC receiver connector, and ESC to LiPo connector
Step 5: Assembly of Track
connect the 80mm diameter pipe, into a 60m long straight track, temporarily blocking off both ends
Step 6: RACE!
After trailing the breaking mechanism and EDF without incident you are ready to race your hyperloop down the pipe, connect the soldered connections to their respective component, insert the main sponge capsule, place it in the tube and use the RC transmitter to power your carriage down the track!
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    3 Discussions
    Ankit1800
    Ankit1800
    Question 2 months ago on Step 2
    How the braking mechanism works??
    seamster
    seamster
    1 year ago
    This is so cool!
    Was this done for an engineering class, or . . ? Very curious to know where you get to do this kind of project! : )
    2317889c
    2317889c
    Reply 1 year ago
    Thanks! Well yes sort of, me and my group are 2nd year product design engineering students at Glasgow university and Glasgow school of art. If you are interested in seeing more of the projects that we do I have a folio page https://www.facebook.com/Eoghan-Condie-Creative-Works-1128169107304493/ where I post most of the work we do (I am going to update it with work we did this year asap). Hope this helps :)
