DIY LED 12v DC Street Lights (Solar Compatible)
2,136
19
4
About: Necessity is the Mother of Inventions they say, I live in challenging land called INDIA. where the Sub par conditions like power issues, heat, Dust and environmental factors are just tough! and They have for...
Outdoor lights are neat nifty lights that have a wide variety of uses.
They keep your houses safe from burglars
They prevent you from tipping over wandering at night
They light the road so you drive safer
or They simply make your place look brighter and nicer.
Here we will be making totally waterproof, Low cost LED Outdoor lights that can be used as Garden lights, Street lights, Security lights or whatever you can think of!
Materials Required-
LED Heatsinks
5050 LED strip
Copper wire
Soldering Equipment
Adhesives.
Next page please.
Supplies:
Step 1: Find Heatsinks
Heat is mortal enemy of the LED.
Its imperative you find some decent Heatsinks for the LED. Although the LED we are using doesn't heat terribly, but the heatsink still helps. I have used some pieces of scrap Aluminum Pipes. Not only they draw heat well, They form the base of LED Fixture as well as Mounting support.
Step 2: Find the LEDs
This will depend on your Light & Voltage Requirements. We have used simple DC 12v LED strips. The benefit here is we can skip the clumsy drivers/ Resistors as these Strips are designed for run Directly on a 12v battery. Thats perfect for my 12v DC Solar project!
The LEDs I brought are SMD 5050 Waterproof & Non waterproof Strips. They come in 5 meter rolls.
The waterproof ones will be used outdoors, The regular ones will be used in shaded locations or Indoors.
Step 3: Paste Strips on Heatsink
Simply glue the strips on heatsink pipes. You can use adhesive or Hot glue. Just don't trust the adhesive backing of LED strips. Its Not good. You will also need to solder the required length of cables & Drill holes of Mounting!.
Step 4: And Thats Done!
Now what remains is to simply connect the street light to 12v battery/Switch/Transformer/sensor for your respective use. And there you have it! Simple & efficient DC LED street lights.
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    4 Discussions
    bhvm
    2 years ago
    Images Updated as said.
    Hi and welcome!
    We're glad you want to share something with the community, and this project looks very interesting. However, in order to be published this project must only contain original images created by you. Please replace any stock or otherwise borrowed images with your own.
    Once you do that, leave me a message and we will publish your work!
    Thanks,
    Your friendly neighborhood instructables staff.
    DIY Hacks and How Tosbhvm
    Reply 2 years ago
    Most of the images in the introduction appear to be borrowed from other websites.
