DIY LED Epoxy Resin Wood Wall Art
Introduction: DIY LED Epoxy Resin Wood Wall Art
About: Hi Everyone, I'm Jeremy Hoffpauir. I write instructables about unique DIY woodworking and home improvement projects. I use unique design elements with a rustic coastal style in my creations such as epoxy...
In this resin art tutorial, I show you how to make LED Epoxy Resin Wood Wall Art inspired by Mardi Gras in New Orleans.
Also, checkout my blog for more projects and online store for DIY plans and my handmade items for sale.
I decided to build an LED epoxy resin wood wall art and experiment with a few resin techniques.
Additionally, I made a few major mistakes during this project. In turn, I had to get creative to salvage the project so be sure to read the entire post to learn more. This LED epoxy resin wall art contains purple photoluminescent powder (glow powder) in the bottom resin layers. Additionally, I used a technique to create a hollow tunnel for the LED light strip. Essentially, the hollow tunnel makes it easy to replace the LED light strip. This resin art tutorial contains many useful techniques & tips to help anyone who wants to create LED epoxy resin wood wall art.
Mardi Gras Art
Furthermore, this wood wall art was inspired by Mardi Gras. I was born and raised in south Louisiana where Mardi Gras is a big part of our culture.
By the way, there is much more to Mardi Gras traditions than the debauchery most people see on Bourbon street after parades. :)
Tools and Material I Used
Epoxy Resin
Purple Glow Powder
Odie's Wood Butter
RO125 Sander
Soft Sanding Pad
40 grit sandpaper60 grit sandpaper80 grit sandpaper100 grit sandpaper120 grit sandpaper150 grit sandpaper220 grit sandpaper320 grit sandpaperVacuum for SanderWool Skin Pad
Bandsaw
Track Saw
MFT Table
Furniture Wax
Vaseline
Hot Glue Gun
Clamps
1/4" clear tubing
Mardi Gras Beads
Heat Gun
Rubber Mallet
Soft Rags
Chisel Set
LED UV Light Strip
Rocker Switch w/ Wire Leads
9v Battery
9v battery connectors
Solder
Step 1: Tools & Material Used
Step 2: Prepare Wood
This piece of cypress wood is roughly 5 inches thick and very uneven. Obviously, this is too thick for a resin art project. In order to use the entire piece of wood, I needed to resaw it into 3 - 1 1/4" each.
First, I used a flat 2x6 to use as a bandsaw resaw jig. This resaw jig provides a flat surface to use as a point of reference for the first cut.
Next, I drilled various pilot holes and countersunk each of them. I used screws slightly larger than the 2x6 to secure it to the cypress.
Then, I made a mark on the cypress 1.25" and setup my bandsaw fence so the mark lined up with the blade. I slowly ran the wood through while allowing the blade to do the work.
I removed the screws and ran the cypress wood through the bandsaw 2 more times with the flat side against the fence.
Once complete, I had 3 beautiful pieces of live edge cypress wood.
Step 3: Prepare Resin Mold
First, I used the same piece of particle board as in my previous resin wall art project. However, the tape was torn in a few spots.
So, I covered the particle board with tape.
Next, I covered the entire piece in furniture wax. Keep in mind, vaseline works just as well as furniture wax.
Step 4: Secure Wood in Resin Mold
After the packing tape was covered in resin, I secured the wood to the particle board with scrap wood cauls and clamps.
Next, I sealed on each side in the middle of the river and on each end.
Step 5: Embed LED Light Strip in Epoxy Resin
In previous projects, I glued UV LED light strips to the bottom of the river. Ultimately, I use UV LED light strips to charge glow powder if sunlight is not present.
Obviously, this isn't ideal because the LED light strip falls over time. Plus, it is visible.
I thought of a way to create a hollow tunnel in epoxy resin large enough to hold the UV LED light strip. Essentially, the hollow tunnel makes it easier to install and replace LED light strips.
I simply use 1/4" clear flexible tubing with a rod in the middle to keep it straight. Hot Glue seals each end and prevents resin from leaking in.
The tube is embedded in the resin and the same size as the wall art. Keep reading to see how this works.
Step 6: Mix Epoxy Resin
First, I mixed 16 ounces of Total Boat high performance epoxy resin. This was my first time using this resin and I really liked how it performed.
Next, I used a separate container to further mix the epoxy resin per the manufacturer's instructions.
Step 7: Add Photoluminescent (Glow) Powder
I frequently use glow powder in many of my resin tables such as this epoxy resin ocean table. Furthermore, I use glow powder from ArtnGlow because it performs the best.
First, I added 1 ounce of purple glow powder to the 16 ounces of resin and thoroughly mixed. I prefer to add the glow powder after I mix the epoxy resin to ensure the resin mixes properly.
Next, I poured the first layer of resin. I always cover the bottom of the river with resin and check for any leaks.
Ultimately, my first resin pour contains just enough resin to cover the bottom and come up about 1/8". The small mixture minimizes the resin waste if I do have a leak.
Then, I used my mini torch to remove air bubbles.
I allowed the LED Epoxy Resin Wood Wall Art to cure overnight.
Step 8: Second Resin Pour
First, I mixed another 16 ounces of resin with 1 ounce of glow powder for the second pour. I poured the resin onto the previous layer.
Then, I removed air bubbles and allowed the resin to cure for 12 hours.
Step 9: Embed Beads in Resin
Since this is Mardi Gras Wall Art, I embedded Mardi Gras beads in epoxy resin.
First, my son spread the green and gold beads on top of the bottom 2 layers of epoxy resin and glow powder.
Next, I mixed 14 ounces of resin and poured the resin on top of the beads.
Then, I removed bubbles with my heat gun.
Ultimately, the heat gun works well at moving the resin around via heat. However, it may contaminate the resin with dust if dusty is present
I let the resin cure overnight.
Step 10: Third Resin Pour
First, I mixed 22 ounces of epoxy resin.
Next, I poured the resin on the LED epoxy wall art.
Then, I used my heat gun to remove resin air bubbles.
Step 11: Final Resin Pour
After roughly 4 hours, I repeated the process above.
First, I mixed 22 ounces of resin and poured it on the LED epoxy resin wood wall art.
Then, I removed bubbles from resin using my heat gun.
I let the epoxy resin cured for 24 hours.
Step 12: Remove Resin Mold
First, I used my rubber mallet to remove each end of the resin mold.
Next, I simply lifted the resin wood wall art from the resin mold. It popped off the packing tape with little effort.
Step 13: Trim Ends
First, I used my track saw to cut 1" off of one end.
Next, I used this straight cut as a reference and used my tape measure to make marks at 33".
Then, I used my track saw to cut along the lines.
Step 14: Remove Rod From Clear Tube
First, I used a pair of pliers to remove the rod from the clear tubing.
The tubing stays embedded in the resin, but the rod is removed.
Next, I pulled the rod completely out of the clear tube.
Once complete, the tunnel was perfect.
Step 15: Planing Mistake & Sanding
I decided to use my router and router sled to flatten the LED epoxy resin wood wall art.
Also, I thought I hit record on my camera to capture this step. However, I realized after I did not.
Resin Mistake #1
I quickly realized after the first few passes with my router that I set my router bit about 1/16th too deep. Consequently, I shaved off the top of the Mardi Gras beads. Ultimately, I contemplated scrapping the entire thing and started from scratch. However, I kept encouraging myself there has to be a way to fix this. The remedy to this problem certainly would not reveal itself to me while I was angry with myself. So, I decided to sand the wall art and call it a day.
Resin Sanding Technique
I used the same sanding technique for this LED epoxy resin wood wall art as I did on wood & resin baseball bat rackI built for my son. The picture below shows the top of the beads I accidentally removed as I explained in the last step. First, I started with 40 grit sandpaper for this resin wall art because the router bit left small lines. Next, I worked in 12" x 12" sections sanding horizontally then vertically in a tic-tac-toe pattern. Then, I repeated the process for 60, 80, 100, 120, 150, and 220 grit sandpaper.
For the 320 grit sandpaper, I swapped the sanding pad in my sander to a soft sanding pad and repeated the process.
Step 16: Repair Beads
The following day I came up with an idea.
First, I mixed 4 ounces of epoxy resin and split the resin into 2 containers.
Next, I used metallic pigment to match the color of the beads.
Then, I lightly placed the resin on top of the shaved beads as carefully as I could.
Step 17: Apply Finish
First, I wiped the surface with a damp rag to remove the dust from sanding.
I used Odie's Wood Butteras the finish for the LED epoxy resin wood wall art. This is my first time using this product and I was really impressed.
Next, I used a paint stick to put clumps of wood butter in various spots on the surface.
Keep in mind, this stuff goes a long way so I made sure to not use too much.
Then, I used a rag and worked the wood butter into the wood and resin.
Once the wood butter set for roughly 30 minutes, I used my sander with a wool skin buffing pad to buff the wall art.
Step 18: Mistake #2 & Repair
I knew I didn't completely cover the clear tube in purple resin as I intended, but I figured I would cross that bridge when it was time.
Until now, I didn't realize the rear of the LED strip is pure white. Houston, we have a problem!
The LED lights are meant to point down facing the back of the resin wall art. However, this exposes the white back of the LED strip and makes it look very silly.
Essentially, the LED light strip would not be visible if it were encased in purple resin as I intended to do.
Well, time to get creative and fix this.
Resin Repair #2
In order to hide the back of the LED light strip, I painted the back the same color as the resin.
First, I tested the acrylic purple paint and it was not the same color purple as the resin.
So, I mixed in some red paint with purple paint. The color looked like it needed more red so that's what I added to it.
This worked! It matched perfectly.
Then, I painted the back of the LED light strip as best as I could with a chip brush.
Step 19: Install LED Light Strips
Finally, it was time to test my tunnel and install UV LED strip lights in epoxy resin.
Although I used resin glow powder, it still needs to charge via natural light or UV black lights.
Also, I choose to install UV LED lights on my resin glow projects in case light is minimal or non-existent.
The LED light strip fit perfectly in the tube, which made it difficult to pull/push through.
Next, I used the rod I removed in a previous step to push the string through the tunnel to the other side.
Then, I tied the string to one end of the LED light strip and pulled it through.
I cut the LED light strip between the 2 contact points with roughly 5" of slack.
Step 20: Install 9v Battery for LED Power
Although the UV LED light strip is 12v, I used a 9v battery to power it.
Essentially, I figured this would work since I only used 2/3 of the LED strip.
First, I flipped the resin wall art over and used my chisels to carve a rectangle in the wood the same size as the 9v battery. Additionally, I accounted for the 9v battery connector.
I'll elaborate more on this in the next step.
Then, I used a scrap piece of wood and a screw to construct a latch to keep the battery in place.
Step 21: Toggle Switch
First, I used my helping hands to solder the toggle switch and 9v battery connector.
Also, the wiring diagram and solder instructions are within the DIY plans. So, be sure to download yours today.
I carved a section for the toggle switch and secured it in place with hot glue.
Step 22: Test LED Lights
I turned off the lights and tested the LED light strips while the resin wall art was upside down. In other words, this side won't be seen.
The second picture is a front view.
Step 23: Conclusion
I failed a lot, learned a lot, and recovered enough to call this LED epoxy resin wood wall art project a success.
In conclusion, I hope this post provided you with value.
Be the First to Share
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    • Tinkercad Student Design Contest
    2 Discussions
    jessyratfink
    jessyratfink
    1 year ago
    Great tutorial! Love that you included what did and didn't work :D
    jeremyhoffpauir
    jeremyhoffpauir
    Reply 1 year ago
    Thank you very much! I came close to scrapping the entire project, but decided to roll with the mistakes. I'm glad I did. :)
