DIY Lithium LiFePo4 12v 18 Amp Battery
Introduction: DIY Lithium LiFePo4 12v 18 Amp Battery
About: Hi my name is Steve and i'm a Creative and I got Technical skills i can build anything just stick to my account . I'm a YouTuber so you also can see my all videos here https://www.youtube.com/SteveWillsonKujur
Hey! everyone My name is Steve
Today I’m Gonna show how I build this 12V 4S3P LiFePo4 Battery Pack With BMS and Balance Charging
Click Here to See The Video
Let's Start
Teacher Notes
Step 1: Features
Total Output Power
  • 18000 mAh @ 12.8V
Input Power " Charging "
  • 9000 mAh Constant Current
  • 14.6v Constant Voltage
Built-in Protection
  • Over Load Protection
  • Short Circuit Protection
  • Over Heat Protection
  • Low Voltage Protection
  • Over Voltage Protection
  • Cell Balancing
Note - Please see the images for better understanding
Step 2: Thing I've Used
LCSC
Banggood
Amazon
Aliexpress
Step 3: LiFePo4 Battery
These are really high-quality FBTech 32650 Cells this cells can easily get you 2000-2500 Cycles these are rated for 3C I’ve Personally Capacity Tested these cells and the result 100% what they are Rated for and I got 6000mAh
I love this Chemistry LiFePo4
Step 4: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 5: Wiring Diagram
Step 6: Assembly
  • Make sure all the batteries are at the same voltage and same capacity
  • Now Assemble the holders
  • Now put one by one cell into the battery holders
  • Now use Kapton tape to tape it all
Kapton Tape - it is used to avoid the heat basically it is a heat resistance tape
Step 7: Welding
For Welding, I Used Spot Welder don't use soldering Iron It may damage your battery
  • Now cut down the Nickle plated strip tape at the Right Length
  • First, make a pair of 3 parallel battery as shown in the picture
  • and then connect all the 4 pair in series
  • This connection is called 4S 3P
  • You can also see the connection diagram above
4S - Stands for 4 Series
3P - Stands for 3 Parallel
Step 8: Battery Management System
To insulate the BMS From Battery I used 2-3 layer of Kapton Tape and Dual Sided tape
Step 9: BMS Wiring
I used 22 AWG Silicone wire and cut it to the right length and soldered wire according to Wiring Diagram and used XT60 As Output
Step 10: Finished
The Battery Has Been Finished I used a 55 Watt Car Headlight Bulb H4 to Test It and it Glows Very Bright
That's all for today guys!
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
Be the First to Share
    • Tiny Speed Challenge
    • Clocks Contest
      Clocks Contest
    • PCB Design Challenge
    3 Discussions
    Andrea PaolaC
    Andrea PaolaC
    16 days ago on Step 5
    Me puedes explicar este diagrama ?
    Y cómo es el nombre de esa tarjeta? Y qué trabajo hace esta tarjeta?
    Gracias
    Andrea PaolaC
    Andrea PaolaC
    17 days ago on Step 10
    Hola, yo tengo un proyecto para un drone.
    Tengo un drone matrice 600 y tiene una capacidad de vuelo de 40 minutos, necesito hacer que vuele 60 minutos. Había pensado en juntar sus bateria solo en paralelo para que aumente la corriente y de ese modo aumente el tiempo de vuelo de este drone. ¿Voy por el camino correcto?
    robertsteel
    robertsteel
    4 weeks ago
    The problem as I see it seems to be securing cells that actually are what you purchase . There are 90 % fraud cells on Ali express.
    Do you have a direct link to the cells you actually tested and used?
    There is a link to ali express but that sellers comments have some pretty bad reports in it.
    I wish to build one of these but at $9 a pop I'm reluctant to just take chances.
    BTW if you pull more than .5C current out of an LFP ,LiFePo4 cell you will seriously degrade the cells and cycle times. At 5 Ah per cell thats 2.5 Amps per cell draw or 7.5 amps for 3 in parallel so I would not draw any more than 7.5 Amps continuous for any length of time from your completed battery if you want them to be long lived . The technology for LFP has not changed for 5 years.
    Good Instructable though Thanks.
