DIY Making USB Power Splitter
Introduction: DIY Making USB Power Splitter
About: Love learning, love life, love traveling
The USB socket is one of the electrical interfaces that are used frequently every day. It is often used only for power supply. The USB HUB is used as an interface extension only when data is being transmitted. If the USB interface is not enough, USB HUB will be selected for expansion. Then, in the case that multiple USB devices that require daily use only need power supply but the interface is not enough, you can make a simple USB power splitter by yourself, then you can output multiple power supplies through one interface, of course, you must The normal use of each device can only be guaranteed when the USB power supply is sufficient. Then this article will show you how to make a USB power splitter yourself.
Teacher Notes
Step 1: Material Preparation
1.USB male
2.USB female 4
3.1 plastic case
4, LED, each one
5.Universal board (hole board)
6, wire tools, etc.
Step 2: Ready for USB Female
Prepare 4 USB female sockets, and arrange the soldering connections according to the definition of their pins. The two main pins are VCC and GND, and the other two data lines are left floating:
Step 3: Universal Board
The circuit board is directly soldered with a universal board
Step 4: LED
The red LED is used as the power indicator. At the same time, a current limiting resistor needs to be prepared
Step 5: Component Welding
Weld four SUB female sockets and one USB male socket according to the principle diagram, and solder the LEDs at the same time
Step 6: Welding Completed
Effect of welding completion
Step 7: Back
Wiring on the back of the universal board
Step 8: Slotted Plastic Box
Cut and polish the box according to the corresponding position of the USB seat of the circuit board
Step 9: Cover and Screw Preparation
Step 10: Installation
Mount the circuit board to the box
Step 11: Lock the Screws
At this point, the power-on test passes and the DIY installation is complete.
Step 12: Effect Map
Let's take a look at the finished product of the USB power splitter made this time. The effect of 1 minute and 4 is mainly composed of a USB male socket and 4 USB female sockets. The USB male socket is used as the input of the power supply, and the four USB female sockets are connected in parallel as the output to realize the function of 1 minute and 4
Step 13: Design Principle
The circuit principle of this work is very simple, mainly using the parallel output of the USB female socket. The red LED is used as the power indicator. The definitions of the four USB port pins are VCC, -D, + D, and GND.
Step 14: Notes: Where Do I Buy These Electronic Components?
In this DIY process, I used all kinds of electronic components, such as LED, resistance and so on. I bought them from veswin,I chose them because their products are the most cost-effective. Of course, it's up to you to buy them from which shop, but it's necessary to compare more shops to choose from.
Step 15:
Step 16:
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
