DIY Massive 12000 Watts 230v Programmable Lighting Setup 12 Channel
About: I like to make diy electronics,electrical and life hacks projects.
Hello everyone,
In this project I will show you how you can make a massive 12000 watts led light controller.
This is a 12 channel setup, by using this circuit you can control any 230v light.
You can make different pattern of lighting. In this video I will show you a demo programming but you can make it according to your requirement.
At first I wanna thank to JLCPCB.COM for sponsoring my video.
They provide some amazing deal on quality pcb. 10 pcbs under $2, just great.
So thanks to jlcpcb again....
So let's make the project..
Step 1: First Watch the Video
Step 2: Order the Pcb
As I told earlier, I order my pcb from jlcpcb.com....
Not only the price, the quality of the product is very good at this price.
Also the shipping is very fast..So you can also order your pcb from jlcpcb.com...
Here is the gerber file of this project....
https://drive.google.com/file/d/15ZiawFZ5NGEOYvQ4GilMNaLMR7vdOptG/view?usp=sharing
Step 3: Components Required
1. Arduino Uno
2. BT 136 TRIAC*12
3. MOC3021 OPTOCOUPLER IC *12
4. 220 OHMS RESISTOR*24
5. 10K RESISTROR*1
6. 20 MHZ CRYSTAL*1
7. 1000UF CAPACITOR....25V
8. 6 PIN IC BASE*12 (OPTIONAL)
9. 28 PIN IC BASE (OPTIONAL)
10. 230V LIGHT*12 11. LAMP HOLDER*12
12. 230V POWER SOCKET
13. 5V,1 AMP POWER SUPPLY
NOTE- ALL THE RESISTORS ARE .25 WATT
Step 4: Circuit Diagram
Step 5: Program the Arduino
Step 6: Assemble the Circuit
Now put all the components to the board & solder it...
Step 7: Connect the Power Supply
Now connect the 230v power supply & the 5v power supply....
Also connect the load..
Step 8: Not to Do
Please do not touch any component while the circuit is connected to 230v supply...
230v Ac supply can kill you.
If you not aware about 230v ac the please stay out of this....
Otherwise do it as your own risk...
" The author is not responsible for any unwanted situation"
Step 9: Tips
If you use 1000 watts each channel then use heat sink ....
Also if you don't want 12 channel then modify the program & set it according to your need...
Also you can write different program..
Step 10: Done
Now you are done....
Now you can use this setup anywhere you want....
Thanks for visiting this page...
You can subscribe my YouTube channel for more updates...
www.youtube.com/howtobro
Thannk You.
Have a good Day!
    • Pie Contest
      Pie Contest
    • Epilog X Contest
      Epilog X Contest
    • Trash to Treasure
      Trash to Treasure
