DIY Mini CNC Laser Engraver.
120,262
728
74
This is an Instructables on how I Remixed my old CNC Laser engraver and made a Stable version of an Arduino based Laser CNC engraver and thin paper cutter using old DVD drives and using 250mW laser.
Old Version of My CNC :https://www.instructables.com/id/Mini-CNC-Laser-Wood-Engraver-and-Paper-Cutter/
Old version was not much stable and had some wobble due to uneven parts, so I decided to make a stable version of it using 3D printed parts. Which gave me excellent results in laser engraving even in very tiny details, this machine is cable of doing the work well. You can see the details in the eye of the engraved picture.
Playing area is 40mm x 40mm max.
Teacher Notes
Step 1: Parts and Materials Required
  • Arduino Nano (with USB cable)
  • 2x DVD drive stepper mechanism
  • 2x A4988 stepper motor driver modules (or GRBL shield)
  • 250mW Laser with adjustable lens (or above)
  • 12v 2Amps power supply minimum
  • 1x IRFZ44N N-CHANNEL Mosfet
  • 1x 10k resistor
  • 1x 47ohm resistor
  • 1x LM7805 voltage regulator (with heatsink)
  • Blank PCB Board
  • Male and Female Headers
  • 2.5mm JST XH-Style
  • 2pin male connector
  • 1x 1000uf 16v capacitor Jumper cables
  • 8x small neodymium magnets ( which I have salvaged from DVD lens mechanism)
  • 1x 2pin plug in screw terminal block connector
  • Zip ties (100mm)
  • Super Glue
  • 6x M3x12 screws
  • 8x M2x5 screws
  • Laser Safety Glasses
"LASER SAFETY GLASSES are must needed in this project".
Step 2: Printed Parts
STL files, see the attached file or go to : https://www.thingiverse.com/thing:3521286
All Parts are printed in ABS material.
Print Settings:
Layer height: 0.2mm
Infill: < 25%
Supports: No
Step 3: Taking Apart the DVD Drive Stepper Mechnaism
Two DVD driver mechanism are required, one for the X-Axis and the second for the Y-axis.
Using a small Phillips head screw driver I removed all the screws and detached stepper motor, the sliding rails and the follower.
The stepper motors are 4-pin Bipolar Stepper Motor.
The small size and low cost of a DVD motor mean that you can't expect
high resolution from the motor. That is provided by the lead screw. Also, not all such motors do 20 steps/rev. 24 is also a common spec. You'll just have to test your motor to see what it does.
Procedure for calculating the resolution of the CD Drive Stepper motor:
In order to measure the resolution of the CD/DVD drive stepper motor,
a digital micrometer was used. The distance along the screw was measured. The total length of the screw using a micrometer, which turned out to be 51.56 mm. To determine the lead value which is the distance between two adjacent threads on the screw. The threads were counted to be 12 threads within this distance. Lead = distance between adjacent threads = ( total length / number of threads = 51.56 mm) / 12 = 4.29mm/rev. The step angle is 18 degrees which corresponds to 20 steps/revolution. Now that all the information needed is available, the resolution of the stepper motor could be calculated as shown below: Resolution = (Distance between adjacent threads) / (N Steps/rev) = (4.29mm/rev) / (20 steps/rev) = 0.214 mm/step. Which is 3 times better the resolution required which is 0.68mm/step.
Step 4: Preparing the Slider.
Using Super Glue I've glued the slider and the guide into one part. Spring is attached to maintain the tension between the guide and the lead screw to avoid black-lash.
Step 5: Assembling the Slider Rails for the Y-Axis
Before assembling the slider into the base I've glued 4x small neodymium magnets ( which I have salvaged from DVD lens mechanism) into the X-plate. This magnets will helps in holding the work piece to the working area.
The smooth rod will keep the sliding mechanism intact to the base.
Step 6: Assembling the Slider Rails for the X-Axis
Here, using super glue and screw I've attached the guiding mechanism to the laser housing.
Attached the stepper motor onto the place using the screws and afterwards inserted the smooth rods and guiding part into the holes given by keeping in mind that slider is moving freely not too hard. And attached the side frame pillars to it.
Step 7: Wiring of Stepper Motors
For the stepper motors I've used old usb cable, because it has 4 wire inside and have a cover on it, and it is more flexible and easy to work with.
Using continuity mode in Multimeter determine determine 2 Coil, Coil A and Coil B.
I made 2pairs of wire by selecting colours, one pair for the Coil A and second for the Coil B.
Soldered them and used heat shrink tube on it.
Step 8: Combing the X and Y Axis
Using 4x M3x12 screws, combined the base and two side frame into one assembly.
Step 9: The Electronics
PARTS USED FOR THE DRIVER ARE:
  • Arduino Nano.
  • 2x A4988 Stepper motor drivers.
  • 1x IRFZ44N N-CHANNEL MOSFET.
  • 1x LM7805 Voltage regulator with Heatsink.
  • 1x 47ohm and 1x 10k resistor.
  • 1x 1000uf 16V capacitor.
  • 1x 2.5mm JST XH-Style 2pin male connector.
  • MALE and FEMALE Header Pins.
  • 1x (20mm x 80mm blank PCB).
In GRBL the digital and analog Pins of Arduino are reserved. The
'Step' pin for the X and Y axes is attached to digital pins 2,and 3 respectively. The 'Dir' pin for the X and Y axes is attached to digital pins 5 and 6 respectively. D11 is for laser Enable. The Arduino gets power through the USB Cable. The A4988 Drivers through external power source. All ground share common connections. VDD of A4988 are connected to 5V of Arduino. The laser I've used runs on 5V and has built in constant current circuit. For the constant 5V source from the external power supply LM7805 voltage regulator is used. Heatsink is compulsory. The IRFZ44N N-CHANNEL MOSFET works as an elelctronic switch when receives digital high signal from pin D11 of Arduino. NOTE: 5V from Arduino nano can't be used beause the laser draws more than 250mA and the Arduino Nano is not capable of delivering that much of current.
Configuring Micro Stepping for Each Axis.
MS0 MS1 MS2 Microstep Resolution.
Low Low Low Full step.
High Low Low Half step.
Low High Low Quarter step.
High High Low Eighth step.
High High High Sixteenth step .
The 3 pins (MS1, MS2 and MS3) are for selecting one of the five step
resolutions according to the above truth table. These pins have internal pull-down resistors so if we leave them disconnected, the board will operate in full step mode. I've used the 16th step configuration for smooth and noise free. Most (but certainly not all) stepper motors do 200 full steps per revolution. By appropriately managing the current in the coils it is possible to make the motor move in smaller steps. The Pololu A4988 can make the motor move in 1/16th steps - or 3,200 steps per revolution.The main advantage of microstepping is to reduce the roughness of the motion. The only fully accurate positions are the full-step positions. The motor will not be able to hold a stationary position at one of the intermediate positions with the same position accuracy or with the same holding torque as at the full step positions.Generally speaking when high speeds are required full steps should be used.
Step 10: Assembling the Electronics to Frame.
Assembled the driver board on the back plate using 2x M2 screws and to the frame of the machine using 2x M3x12 Screws. Plugged in the connections for the Stepper motors X ,Y and the Laser.
Step 11: Adjusting the Stepper Driver Current
To achieve high step rates, the motor supply is typically much higher than would be permissible without active current limiting. For instance, a typical stepper motor might have a maximum current rating of 1A with a 5Ω coil resistance, which would indicate a maximum motor supply of 5 V. Using such a motor with 12 V would allow higher step rates, but the current must actively be limited to under 1A to prevent damage to the motor. The A4988 supports such active current limiting, and the trimmer potentiometer on the board can be used to set the current limit. One way to set the current limit is to put the driver into full-step mode and to measure the current running through a single motor coil without clocking the STEP input. The measured current will be 0.7 times the current limit (since both coils are always on and limited to 70% of the current limit setting in full-step mode). Please note that changing the logic voltage, Vdd, to a different value will change the current limit setting since the voltage on the “ref” pin is a function of Vdd. Another way to set the current limit is to measure the voltage directly on top of the potentiometer and to calculate the resulting current limit (the current sense resistors are 0.1Ω). The current limit relates to the reference voltage as follows: Current Limit = VREF × 1.25 So, for example, if the reference voltage is 0.6 V, the current limit is 0.75A. As mentioned above, in full step mode, the current through the coils is limited to 70% of the current limit, so to get a full-step coil current of 1A, the current limit should be 1A/0.7=1.4A, which corresponds to a VREF of 1.4A/1.25=1.12 V. See the A4988 datasheet for more information. Note: The coil current can be very different from the power supply current, so you should not use the current measured at the power supply to set the current limit. The appropriate place to put your current meter is in series with one of your stepper motor coils.
Step 12: Laser Assembly
The laser I've used is Focusable Laser Module 200-250mW 650nm. The outer metal housing work as a Heatsink for the laser diode. It has focusable lens for the adjustment of laser dot. Connect the laser wire terminal to the laser socket on the driver board.
You can get one Here.
Step 13: Getting Ready!
Using four small Neodymium magnets lock the working piece on the working bed and set the X and Y-axis to initial position (home). Power up the driver board through External power source, and Arduino Nano to Computer through a USB A to USB Mini B Cable.
Also power the board through a external power source.
SAFETY FIRST.
LASER SAFETY GLASSES ARE MUST NEEDED
Step 14: GRBL Firmware
  1. Download the GRBL , Here
  2. Extract on the desktop the grbl-master folder, you find it in the file master.zip
  3. Run the Arduino IDE
  4. From the application bar menu, choose: Sketch -> #include Library -> Add Library from file.ZIP
  5. Select the folder grbl that you can find inside the grlb-master folder and click on Open
  6. The library now is installed and the IDE software will show you this message: The library is added to your library. Check the “libraries Inclusion” menu.
  7. Then open an example called "grbl upload" and upload it to your arduino board.
Step 15: Software to Send G-CODE
Also we need a software to send G-Code to CNC for that I've used the LASER GRBL
LaserGRBL is one of the best Windows GCode streamer for DIY Laser
Engraver. LaserGRBL is able to load and stream GCode path to arduino, as well engrave images, pictures and logo with internal conversion tool.
LASER GRBL Download.
LaserGRBL constantly checks for COM ports available on the machine. The list of ports allows you to select the COM port which your control board is connected on.
Please select the proper baud rate for the connection according to your machine firmware configuration (default 115200).
Grbl Settings:
$$ - View Grbl settings
To view the settings,type $$ and press enter after connecting to Grbl. Grbl should respond with a list of the current system settings, as shown in the example below. All of these settings are persistent and kept in EEPROM, so if you power down, these will be loaded back up the next time you power up your Arduino.
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=6 (dir port invert mask:00000110)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.020 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=1 (homing dir invert mask:00000001)
$24=50.000 (homing feed, mm/min)
$25=635.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=314.961 (x, step/mm)
$101=314.961 (y, step/mm)
$102=314.961 (z, step/mm)
$110=635.000 (x max rate, mm/min)
$111=635.000 (y max rate, mm/min)
$112=635.000 (z max rate, mm/min)
$120=50.000 (x accel, mm/sec^2)
121=50.000 (y accel, mm/sec^2)
$122=50.000 (z accel, mm/sec^2)
$130=225.000 (x max travel, mm)
$131=125.000 (y max travel, mm)
$132=170.000 (z max travel, mm)
Step 16: Tweaking the System
Here comes the Most Difficult part of the Project.
-Adjusting the laser beam into the smallest dot possible on the work piece. This is the Trickiest part which require time and patience using trail and error method.
-Tweaking the GRBL settings for $100, $101, $130 and $131
My setting for the GRBL is,
$100=110.000
$101=110.000
$130=40.000
$131=40.000
I tried engraving a square of 40mm sides and after so many error and tweaking the setting of grbl, I get the proper 40mm line engraved from the both X and Y-axis. If the resolution of X and Y-Axis are not same the image will scale in either direction.
Keep in mind not all Stepper motor From DVD Drives are the same.
It is lengthy and time consuming process but the results are so satisfying when tweaked.
LaserGRBL user interface.
  • Connection control: here you can select serial port and properbaud rate for connection, according to grbl firmware configuration.
  • File control: this show loaded filename and engraving process progress. The green “Play” button will start program execution.
  • Manual commands: you can type any G-Code line here and press “enter”. Commands will be enqueued to command queue.
  • Command log and command return codes: show enqueued commands and their execution status and errors.
  • Jogging control: allow manual positioning of the laser. The left vertical slider control movement speed, right slider control step size.
  • Engraving preview: this area show final work preview. During engraving a small blue cross will show current laser position at runtime.
  • Grbl reset/homing/unlock: this buttons submit soft-reset, homing and unlock command to grbl board. On the right of unlock button you can add some user defined buttons.
  • Feed hold and resume: this buttons can suspend and resume program execution sending Feed Hold or Resume command to grbl board.
  • Line count and time projection: LaserGRBL could estimate program execution time based on actual speed and job progress.
  • Overrides status an control: show and change actual speed and power override. Overrides is a new feature of grbl v1.1 and is not supported in older version.
Step 17: Wood Engraving
Raster import allows you to load an image of any kind in LaserGRBL and turn it GCode instructions without the need of other software. LaserGRBL supports photos, clip art, pencil drawings, logos, icons and try to do the best with any kind of image.
It can be recalled from “File, Open File” menu by selecting an image of type jpg, png or bmp
The setting for engraving is different for all materials.
Define the engraving speed per mm and Quality- lines per mm Video Attached is the time-lapse of the whole process.
Step 18: Thin Paper Cutting
This 250mW Laser is Also capable of cutting thin papers, but the speed should be very low i.e. not more than 15mm/min and laser beam should be properly adjusted.
Step 19: Vinyl Cutting and Making Custom Stickers
I have made some Custom vinyl sticker. Boarder speed changes with respect to the colour of the vinyl used.
Dark colours are the easy to work with while the Lighter colours are some tricky.
The above Images demonstrate how to use vinyl sticker which are made using the CNC.
But keep in mind that burning vinyl releases carcinogenic fumes. They smell really bad.
♥ Special thanks to the GRBL Developers :)
I hope you liked this project, let me know in the comments if any queries, I would like to see photos of your CNC machines too!
Thanks!! for Your support.
Remix Contest
Remix Contest
2 People Made This Project!
  • Made with Math Contest
  • Multi-Discipline Contest
  • Robotics Contest
    Robotics Contest
74 Discussions
KINGTECH2
7 days ago
Hi, I'm just finishing the project. All is working except that the laser seem to be not enought strong. I buy the same model than your and try many times to focuse the lens.
Something i made wrong?
Maggie ShahKINGTECH2
Reply 6 days ago
If you're using the same laser as me, then probably there are 2 factors affecting the laser.
1st: Laser is not getting enough power. This laser runs on 5v max and draws more than 300mAh.
2nd: Lens is not focused well. By applying power to laser, try manually to etch some ply wood by focusing, so you can have the appropriate length between the work piece and the laser. After getting this value fix the laser to holder accordingly.
Hope this helps.
rvmarkus
4 weeks ago
I am currently building this (printing the parts) and have come across an issue. In the picture of the complete project, the side supports are secured to the base with two screws. The printed base has holes for the screws, but the side supports don't. Can I just glue them in place or can anyone provide an updated .stl of the side support with the screw holes?
Thanks!
Megazardrvmarkus
Reply 21 days ago
just drill holes into the side parts
Megazard
Question 21 days ago
is there a way to properly shut down/disconnect it from the computer, or do you just un plug the cables?
MartinZ32
3 months ago
MegazardMartinZ32
Reply 2 months ago
wait so does this one come with the stepper modules and the arduino?
BadOneXMartinZ32
Reply 2 months ago
Did you try it with that board, would make it much easier for me if it would work! :)
Megazard
2 months ago
Maggie ShahMegazard
Reply 8 weeks ago
It seems like they are out of stock. but as the name suggest I can say, that's the motor used in CD roms.
BrianD254
4 months ago
Do your 2 stepper motors have to have identical number steps?
Megazard
3 months ago
How hard would it be to make a video guide of putting one of these together?
Maggie ShahMegazard
Reply 3 months ago
Sorry! I don't have any experience in video editing, so i can't tell.
I can say that after printing the parts, assembling and all the electronics would take roughly a hour to complete.
Yes you can use a CNC Shield, its an easy way. Here I've used 250mW laser which is enough for engraving wood, cutting Black vinyl and thin papers. Using High wattage laser have a safety concerns and they generate high heat while running as well.
GridPole
4 months ago
Great project. Looks really clean and well explained. The only part I am getting stumped on is the stepper driver motor resolution calculation. When you are mentioning the screw I assume you are talking about the lead screw and the when you refer to the number of threads I imagine it's the ones on the lead screw as well.
https://cdn.instructables.com/FJ9/1NPF/JSYZ92QT/FJ...
From the pictures there seems to be more than 12 threads. I googled the crap out of how to calculate the resolution but yours has been the simplest and most complete so far. Where/how you are getting the thread count from? Can you please clarify this for me?
Maggie ShahGridPole
Reply 4 months ago
This CD-Rom Stepper motor varies from different manufactures, the calculation is an example how I got the resolution. But in last I used "Trail and Error" method to find the perfect resolution through the G-code sender.
tweaking the setting of grbl in Laser GRBL , To view the settings,type $$ and press enter after connecting to Grbl.
Grbl should respond with a list of the current system settings. All of these settings are persistent and
next time you power up your Arduino. I got the proper 40mm line engraved from
the image will scale in either direction. If the engraved line is less than 40mm, increase the resolution in Laser GRBL ( $100 and $101) and vice versa.
Thank you.
Megazard
4 months ago
Can it engrave in only one shade of black, or can it do grays as well?
Also can you provide a link for Raster Import? I cant find a download link anywhere
