DIY Modern Tripod Floor Lamp
5,202
90
8
Introduction: DIY Modern Tripod Floor Lamp
About: Maker based in ATL, I love to make new things and learn along the way. I want to share my learning experiences with others so they can be inspired to make the things they want as well.
Have you ever seen those designer tripod lamps that are ridiculously expensive, well this week we build one a lot cheaper using a paint bucket and LEDs!
Step 1: Materials
For this project I used:
- A couple of 1x2s
- A small section of 2x4
- Paint Bucket
- Steel Bar
- LED Strip: https://amzn.to/2Glp7bJ
- 12V Power Adapter: https://amzn.to/2DidEci
Step 2: Mark and Cut
The first step in this project was measuring out my legs and then cutting them to size.
Step 3: Shape the Ends
Then using my disk sander I rounded over the ends of the legs to make to break up having so many straight edges.
Step 4: Mark the Holes
Next, I marked the locations for the legs.
Step 5: Drill the Holes
After marking ou the holes I went ahead and drilled them with a 1/4" drill bit for the 1/4" bolts.
Step 6: Making the Center Piece
I traced an equilateral triangle of the right size on a 2x4 and then cut it out on the bandsaw.
Step 7: Leg Assembly
Step 8: Drill More Holes
Then I drilled some more holes to be able to mount up the legs.
Step 9: Make the Lamp
The actual lamp portion of the project I made using a paint bucket that is available at Home Depot. Then I used an LED strip to line the inside of the bucket.
Step 10: Install the Power Jack
The next step was to install the power jack, so I went ahead and drilled a hole, soldered it up and that was done.
Step 11: Install Mounting Bolts and Diffuse the LEDs
I clipped off the handle and enlarged the pre-existing holes and installed the 1/4" mounting bolts. To diffuse the LEDs I just used a bit of parchment paper cut to size.
Step 12: Mark, Cut, Bend
Next up I needed to make a bracket to hold up the lamp portion. To do that I just cut a metal bar to size, marked it, and then scored along those lines with the angle grinder to make it easier to bend it. Then I bent it to the proper shape. Really, you could do whatever you think looks good for this step.
Step 13: Drill Some More Holes
To drill some holes in the bracket, I used a self-centering automatic punch to mark the locations and then drilled some more 1/4" holes.
Step 14: Paint
The only paint I used in this project was to give this bracket a light coat of black.
Step 15: Final Assembly
Then it was time for final assembly, I just drilled a hole into the centerpiece for the bracket to bolt into and then finished butting it all together.
Step 16: It's Done!
That's it, now enjoy the super cool lamp you made with a paint bucket.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    8 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    I really like the simple design! How tall is it? Do you have a picture of the full lamp?
    paolochiarlone
    paolochiarlone
    1 year ago
    Love it!
    One comment: I believe that painting the interior in white would give you a little more bounce hence more reflected light, what do you think?
    Make And Repeat
    Make And Repeat
    Reply 1 year ago
    You're probably onto something! That would have been a great idea, I was going to put aluminum tape on the inside but I think paint would look much cleaner and also match the led strip.
    YaënD
    YaënD
    1 year ago
    as great as simple. mark of genius. I agree with jtredgold and GTO3x2
    jtreadgold
    jtreadgold
    1 year ago on Introduction
    Great project but it would have been better to show a picture of the entire lamp, not just the head.
    Make And Repeat
    Make And Repeat
    Reply 1 year ago
    Thank you! Yea I probably should have done that but the tripod is the simpler part of the project so I didn't really think to do it, next time!
    GTO3x2
    GTO3x2
    1 year ago
    Nice job. All kinds of possibilities.
