DIY Multi-Room Audio
About: Hi my name is Steve and i'm a Creative and I got Technical skills i can build anything just stick to my account . I'm a YouTuber so you also can see my all videos here https://www.youtube.com/SteveWillsonKujur
Hey! everyone My name is Steve.
Today I'm going to show you How to Make a Wifi Audio Streamer using very fewer parts and it's better than chrome cast Audio and you can use it as multi-room setup and it can connect up to 10 Speakers
Click Here to See The Video
Let's Start
Teacher Notes
Step 1: Features
Input Power
  • 5V DC
Output Power
  • 2 X RCA for Stereo Audio Output
        Step 2: Thing I've Used
        LCSC
        LCSC 8$ OFF on your first order - https://lcsc.com/?href=STEVE&source=referral
        Banggood
        Amazon
        Aliexpress
        Note - Please see the images for better understanding
        Step 3: Sponsor
        Today's Article is Sponsored by lcsc.com
        They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
        Step 4: Marking & Drilling
        • I Used a Philips Head Screw Driver to Open the Enclosure
        • And Then I placed the Up2Stream module on top of the Enclosure and used a Center Punch to Punch 4 Holes
        • And then I used a 3mm Drill Bit to Drill the Punches
        Step 5: Marking & Drilling Back Panel
        I used Center punch for marking of 2 RCA Jack, DC jack and wifi antenna
        and then i've drilled 4 holes with a drilling machine
        Step 6: Install
        • First, I've installed DC Socket
        • And then I've installed 2 RCA socket
        • And then I've installed Wifi antenna socket
        Step 7: Stands Off
        I used 4 stands off to give it some clearance
        Step 8: Wire Assembly
        This board comes with 2 wire one is audio output wire and one is power input wire
        The problem is the audio output wire has 4 wire and you only need 3 wire one for Right channel output one for Ground and one for Left channel output,
        The fourth wire is WPS you don't need it
        So, I've cut the forth wire
        Step 9: Enclosure Assembly
        • First, i've connected the wifi wire to the board
        • I used 4 screws to fit the board into the enclosure
        Step 10: Soldering
        • First I've soldered the 3 wires to the RCA socket
        • And then I've soldered the 2 wires to the DC socket
        Step 11: Final Assembly
        • I used 4 screws to fit the back panel
        • And then I used 4 screws to fit the front panel
        Step 12: Rubber Feet
        I used some rubber feet on the bottom
        Step 13: Connection
        Connection
        • First I've connected the RCA Jack
        • Second I've connected the 5v Dc Jack
        • Third I've connected the Wifi Antenna
        Speaker
        • I used my Bluetooth Speaker as my Speaker output Via Aux input
        Step 14: Setup
        • You need MUZO App to setup
        • Open MUZO App Select " Add another MUZO compatible speaker "
        • Select BUSH
        • Select Setting
        • Now connect to "Stream System"
        • Now select the Wifi you want your speaker to connect and enter the Password
        • Now you can keep your speaker Name
        • You are all Set
        • Now go to My Music
        • And Play the Song
        • You can control Your Volume There
        • You Can connect up to 10 Speaker and can play different songs
        Enjoy
        Step 15:
        You Just Made It
        Thank you for visiting my Instructables Stay tuned for next Projects
        Be the First to Share
          • CNC Contest
            CNC Contest
          • Make it Move
            Make it Move
          • Teacher Contest
            Teacher Contest
