DIY Multifunctional Magnetic Therapy Device (PEMF, RIFE ..)
Introduction: DIY Multifunctional Magnetic Therapy Device (PEMF, RIFE ..)
Pulsed ElectroMagnetic Field therapy, also known as PEMF, is a drug-free, non-invasive, pain-relief alternative treatment, which also promotes accelerated healing for ailments and injuries.
Teacher Notes
Step 1: Therapeutic Indications
In addition, PEMF therapy improves sleep, mental focus, and the body’s overall performance by helping the energy output and regeneration of the body’s cells.
Clinical studies have demonstrated that PEMFs are capable of:
Increasing circulation
Decreasing inflammation
Accelerating bone healing
Enhancing muscle function
Reducing the effects of stress
Improving blood oxygenation, and much more.
Step 2: Parts
Тhis device consists of ready-made modules that can be purchased inexpensively from Aliexpress and Ebay, so the price does not exceed 20 $.
https://www.aliexpress.com/item/DC12V-LED-Digital-Time-Delay-Relay-Module-Programmable-Timer-Relay-Control-Switch-Timing-Trigger-Cycle-with/32933710064.html?spm=a2g0s.9042311.0.0.40214c4dTM6PKE
https://www.aliexpress.com/item/1Hz-150KHz-PWM-Pulse-Frequency-Duty-Cycle-Adjustable-Module-Signal-Generator/32922048052.html?spm=a2g0s.9042311.0.0.27424c4dfZs16J https://www.ebay.com/itm/TPA3116D2-2X50W-12V-24V-Digital-Amplifier-Board-Class-D-Dual-Channel-Stereo-AMP/112441617158?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3Dc80ad4f2a6084585b81c9b5deda5d041%26pid%3D100290%26rk%3D1%26rkt%3D3%26sd%3D112441617158%26itm%3D112441617158&_trksid=p2060778.c100290.m3507
Step 3: Schematic
You can use any D class amplifier module with 2x50w or more output power.For powering, I use 19V power adapter from old laptop computer, but you can use any power supply from 10v to 36v with current of 3A or more.The PWM module's exit is connected to one chanel input of power amplifier (PA) . Other input channel of PA is connected to "input" jack on front panel. Outputs of power amlifier are connected to "coil" connectors on front panel. Power amplifier is powered through the timer module relay that is set to run for a specified time (15 to 20 min)."Mono" switch is used for switching between two channel PEMF, or PEMF plus RIFE mode.
Step 4: Making the Device
The pictures show the stages in the preparation of the device.
Making a coil and other useful informations are described in my previous videos :
https://youtu.be/E2IoPbgNGyo
https://youtu.be/7fTTR9T0xL0
Step 5: "RIFE" Device
And now a few words about the device's left channel. "Output" from the PC soundcard should be connected to the "input" of our device. Well, through various PC software we can generate all kinds of signals with different shapes and frequencies.
American scientist Royal Raymond Rife invented the Rife machine. It produces an energy similar to radio waves. Rife’s machine built on the work of Dr. Albert Abrams. Abrams believed every disease has its own electromagnetic frequency. He suggested doctors could kill diseased or cancerous cells by sending an electrical impulse identical to the cell’s unique electromagnetic frequency. This theory is sometimes called radionics.All this is in the domain of speculation and has not been proven to this day. You can find several softwares for generating RIFE frequencies for various diseases on http://www.spectrotek.com/frex/.Тhere is also a web where we can create a set of frequencies on our own : http://www.diypemf.com/cgi-bin/mkfreq.cgi/mkfreq/... In this case(RIFE machine) , instead of a coil, at the exit of the device we connect two cylindrical copper electrodes that during the therapy we hold in both hands soaked in salt water.
Thanks for watching
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    10 Discussions
    edodinox
    edodinox
    Question 4 months ago on Introduction
    Hi,
    My question is, what happens if the resulting inductance in the coil is different from the suggested one, e.g. 50 uH or 10 uH?
    RakiA2
    RakiA2
    Question 5 months ago on Introduction
    Best,
    is this for sale?
    DIY multifunctional magnetic therapy device
    abhalight
    abhalight
    Question 6 months ago
    Hi, I need help to repair my 1970's Tansley radionic machine. Can you help me?
    abhalight
    abhalight
    Answer 6 months ago
    Here it is. I can share more details once you contact me. Thanks.
    The2beve
    The2beve
    Question 11 months ago on Step 1
    Your circuit diagram appears to have fewer resistors than the photos you posted. Is the diagram correct, and I am seeing things, or did you neglect to include a few components in the diagram? I counted 7 based on what I saw in the photo, but your diagram only accounts for 4. Would appreciate some clarification.
    Tito Dj
    Tito Dj
    Answer 8 months ago
    I think the diagram is right, and you're just looking at more resistors because he didn't had the exact impedance, so he had to use some in paralell.
    Levisinsight
    Levisinsight
    11 months ago on Introduction
    Hey would the output on the ride side be able to be hooked up to a plasma bulb like the spooky 2 has available? If so how would that be assembled. I saw a site that has a DIY on making a plasma generator rife but was wondering if I could just adapt it to this DIY? Thank you.
    Levisinsi9ht99@gmail.com
    Levi
    WilkoL
    WilkoL
    1 year ago on Step 5
    Let me quote https://sciencebasedmedicine.org on this device: "If you subscribe to the old adage “Laughter is the best medicine,” you might think this is a useful product. It made me laugh heartily." Thank you.
