DIY Oil and Water Pen
778
5
6
Introduction: DIY Oil and Water Pen
This is a super cool way to make a boring pen fun! Very easy to do with common supplies! And yes! they will write for a while! The ink will eventually stop flowing but for the pens I made they worked for a while before stopping. Defiantly worth making to use and then to have to play around with.
Teacher Notes
Step 1: Gather Supplies
For this you will need a clear pen that can unscrew to remove the ink, oil (i used canola oil, which appears cleat=r in this project), food coloring, and a plastic pipette.
Step 2: Remove the Ink and Seal the Pen
Unscrew the pen and take out the ink.
Then using a hot glue gun, seal any areas on the pen by gluing a thin layer around any openable/potentially not sealed parts. For me this area is the top part of the pen.
Step 3: Dye the Water
Using the food due, dye a small amount of water your desired color
Step 4: Seal the Ink
Now seal the top part of the ink using hot glue. Put a small amount of the glue coverage the opening on the ink. This makes sure no water or oil will get into the the ink cartridge. This step is necessary to make the pen still work after being assembled.
Step 5: Fill the Pen
Now, working in layers with the pipette, fill the pen about 1/2-2/3 full using the oil and water.
Step 6: Place the Ink Back In
Now put the ink in the pen. Its ok if there is space without liquid. Then place a tiny amount of hot glue to keep the ink in place
Step 7: Finish the Pen!
Now screw on the metal part to finish the pen. Carefully seal around the top part of the metal where it meets the plastic and around the bottom where the ink piece meets the metal. Now your pen is ready to use!!
Oil Contest
Oil Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    6 Discussions
    Randomona
    Randomona
    1 year ago
    Interesting idea! :)
    Sticky-Toes
    Sticky-Toes
    1 year ago
    You do realise the pen won't work anymore, right ?
    ksr08
    ksr08
    Reply 1 year ago
    Hi, The pen does in fact work, as long as you seal the open end of the ink in step 4.
    Sticky-Toes
    Sticky-Toes
    Reply 1 year ago
    It's like a straw. If you filled it with a liquid and you plug an end, the liquid won't come out of the other end ! I think the pen will work as long as there is ink on the ball. But eventually the ink will stop flowing to the tip of the pen and then it won't work anymore.
    ksr08
    ksr08
    Reply 1 year ago
    After testing it out further, that does happen, but for me the ink lasts a while before stopping. Long enough that I didn't realize as I was testing out the pen before I posted.
    Uu5Es1I
    Uu5Es1I
    Reply 1 year ago
    I have to agree with Sticky-Toes. Because no air comes inside, pressure will get too low for any more ink to exit. It's still an interesting project. I guess you can instead glue open end of the ink to the cap and make a hole in it for the air.
