DIY Outdoor Side Table
About: My name is Brandon. I am a woodworker and content creator. I have a business building custom furniture for clients but I also create DIY style content on YouTube and other platforms. Hope you guys enjoy! ...
Full build plans with detailed cut list - Click for Plans
Website - https://walkersww.com/
YouTube channel - walkerswoodworks
Instagram - @Walkers_woodworks
Supplies:
Tools and items used in this build (affiliate links included)
Dust mask - https://amzn.to/2Gsp2EP
Makita Drill & Driver set - https://amzn.to/2Gph5jH
Milwalkee tape measure - https://amzn.to/2Gph5jH
Miter saw - https://amzn.to/2Gph5jH
Miter saw blade - https://amzn.to/2Gph5jH
Titebrush - https://amzn.to/2Gph5jH
Bluetooth Earbuds - https://amzn.to/2Gph5jH
Countersink - https://amzn.to/2Gph5jH
Festool ETS EC - https://amzn.to/2Gph5jH
Brad nailer - https://amzn.to/2Gph5jH
Consumables used (affiliate links included)
Spar Urethane - https://amzn.to/2WSI7sB
Construction adhesive - https://amzn.to/2WSI7sB
Titebond 3 - https://amzn.to/2WSI7sB
Sanding sponges - https://amzn.to/2WSI7sB
2 1/2" screws - https://amzn.to/2WSI7sB
1 1/4" screws - https://amzn.to/2WSI7sB
1 1/4" brads - https://amzn.to/2WSI7sB
Teacher Notes
Step 1: Cutting Materials
For this project you will need 2 8ft 2x2's, 2 8ft 1x2's (a good wood for outdoors is cedar or redwood), one 12" by 24" ceramic tile,some Outdoor rated construction adhesive and some outdoor rated finish. I started out by cutting all 4 legs over at the miter saw. Then I grabbed the 1x2 stock and cut the two runners that will be used for the bottom shelf as well as the rest of the pieces for the frame. If you don't have a miter saw you could also use a circular saw or a jig saw.
Step 2: Main Frame Frame Assembly
Attach two of the legs to one of the top frame sides with one screw and wood glue. Than add the 1x2 runner. Do the same steps for one more leg assembly.
Step 3: Top Frame Assembly
Once both sides are assembled you can put them together using the two 2x2 pieces for the top frame ends
Step 4: Attaching the Bottom Shelf Slats
At this point you're ready to dry fit the slats for the bottom shelf. Use two slats cut to fit between the legs and then using a 3/4" spacer, lay out the rest of the slats (cut a bit longer) with a 3/4" gap between each one.
Step 5: Sanding & Finishing
Sand everything with your sander and hand sand those hard to reach areas. Once its all sanded, its time for finish! I used an outdoor spar urethane and did several thin coats, worked great!
Step 6: Attaching the Top
Use outdoor rated construction adhesive to attach the tile top, make sure its centered. Stack weights on it to act as a gravity clamp until the adhesive cures.
Step 7: All Done!
You're finished! Now put it on your porch, deck, patio, take it camping, whatever you like! Enjoy the fruits of your labor! Really appreciate you guys following along and don't for get to watch the youtube video of this build to see it more in depth. Also check out the plans for even more detailed steps and cut lists! Hope you enjoyed! Have a great day!
Also don't forget to subscribe! I'd really appreciate it! SUBSCRIBE
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
