DIY PVC Wakizashi
In this instructable, I will show you how to make your own PVC wakizashi wielded by the people of Nihon Ja in John Flanagan's Ranger's Apprentice series. A wakizashi is traditionally a Japanese weapon worn in a sash around the waist.
Supplies:
  • 2-foot long piece of 3/4-inch PVC pipe
  • 3/4-inch PVC pipe end-cap
  • tape measure
  • permanent marker
  • propane torch
  • bench vise
  • band saw
  • pewter gray acrylic paint
  • metallic gold acrylic paint
  • paint brushes
  • tire inner tube
  • 220 grit sandpaper
  • PVC pipe cement
Teacher Notes
Step 1: Flattening the Pipe
{"context":{"location":{"href":"https://www.instructables.com/editInstructable/publish/EN4W7DIK1L41ZDA","protocol":"https:","host":"www.instructables.com","hostname":"www.instructables.com","port":"","pathname":"/editInstructable/publish/EN4W7DIK1L41ZDA","search":"","hash":"","origin":"https://www.instructables.com","ancestorOrigins":{}},"jQuery112408507983729530123":1},"selector":"#editor-Object-24"}
Step 2: Cutting and Painting the Blade
Shape the end of your flattened pipe into a pointed blade on the band saw. Then paint the blade pewter gray with acrylic paint.
Step 3: Making the Handle
Cut up the inner tube to make a long 1/2-inch wide rubber strip. Wrap it over the handle slightly overlapping. Make sure to leave 1/2-inch on the end of the handle for the pommel.
Step 4: Making the Pommel
Take a 3/4-inch PVC pipe end cap, and lightly sand its surface to make the paint stick to it. Adhere the end cap to the end of the handle using PVC pipe cement. Then paint the end cap with metallic gold acrylic paint.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
