DIY Pethair Handbrush - Anti Clog, Easy to Clean
3,416
46
13
Introduction: DIY Pethair Handbrush - Anti Clog, Easy to Clean
About: Mostly harmless
let me introduce my new favourite (and all recycled) household item:
a handbrush that doesn't clog from all that pethair anymore.
I was tired of my old handbrush, full with pethair all over, impossible to remove - sure, it still works, but is not nice to look at.
3 cats and a dog did their work :)
So I came up with this easy and fast made alternative, made from recycled foam and reclaimed wood.
The result can be used without fear of clogging and can be rinsed in water to clean off any excess debris.
It takes about 1 to 2 hours from start to finish.
And: IT IS CAT APPROVED!
Step 1: What You Need
for the handbrush:
  • a piece of wood, big enough for a handle
  • some screws - I used 3 brass screws
  • craft foam, or foam from packaging .... Try it out on your floors - it should not be too stiff and not to sloppy. - the one used in this instructable, came from a packaging, was medium stiff and quite thin, so I decided to make 3 layers.
  • optional: wood oil or stain
Tools needed:
  • ruler and pencil
  • craft knife or scissors
  • jigsaw, or handsaw
  • a sander, or sandingpaper
  • cordless drill with matching bits
  • optional: a counter sink -makes prettier holes :)
Step 2: Cutting the Foam
with a craftknife cut the foam to pieces of
5cm x 15cm ( 2" x6")
if your foam is quite thin you may want to make more layers - mine was 7mm (0,3") thick so I went for 3 layers.
aim for 2 cm (0,8")
Step 3: Mark the Handle
place another brush on your piece of wood, and trace it - or go freehand - that's totally up to you!
position the foam, so that it as a little excess over the handles edge and trace around it. ( see the pictures )
Step 4: Cut the Handle
cut along your marks with a jigsaw.
Note: it's easier if you clamp it down.
Step 5: Make It Smoooooth
time to sand the handle - unless you like the rough look and feel of raw wood and don't mind splinters to much - then you can skip this step...
otherwise:
clamp the handle down and make the edges round and smooth
I used a power finger and a sander - this could be done with a rasp and sanding paper as well.
Proceed until your pleased with the handle and it feels good in your hand.
- cleaning is unpleasant, so at least the handle of your cleaning tool should be :)
Step 6: Foam Testfitting
insert the foam pieces, they should fit quite flush but with no tension.
if it's too tight, you have two possibilities:
  1. more sanding, until it fits
  2. heat the foam and make it a little more dense: I used a metalpiece and a torch to make the foam fit my handle
Step 7: Holes
predrill holes for the screws, so they won't split the wood.
use a counter sink to make the screws flush with the handles side.
add the screws
Step 8: Oiling or Staining
this step is for the little extra: adding stain or wood oil
-and of course it makes the handle longer lasting and more resistant for stains.
I left grey wood on some parts of my handle because I knew it look awesome when oiled with linseed oil.
Step 9: Angle the Foam
cut the excess foam to an angle
- that'll make your life easier while cleaning corners.
Step 10: Well That Looks Great
Now we come to the less fun part:
CLEANING your floors!
Well well, you have now a great tool that won't clog all the hair from your beloved pets - and that is a big plus!
- and you made it all by yourself!
the next step is about the use and cleaning of the handbrush
Step 11: Use and Cleaning
the handbrush works great on all surfaces in my home, hardwood, tile and laminate flooring.
almost no pethair sticks to the brush, and if it does it's simple to remove.
Of course it works also for all other stuff: dust, bread crumbs...
the best part is: just rinse it under water to get rid of dust and other debris stuck to the brush.
- If you rinse it a lot, don't forget to renew the wood oil to protect the handle.
I can highly recommend this brush to every pet owner!
Step 12: CAT PIC FRENZY
For all of you that can't get enough of cat pictures:
I hope you enjoyed your stay!
Yours
Mimikry
Pets Challenge
Runner Up in the
Pets Challenge
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Bikes Challenge
      Bikes Challenge
    13 Discussions
    LeslieGeee
    LeslieGeee
    1 year ago
    Great idea and instructional, thank you for sharing :)
    Mimikry
    Mimikry
    Reply 1 year ago
    Thank you for your comment :)
    OutofPatience
    OutofPatience
    1 year ago
    What a great idea...and your instructions are clearly illustrated...thanks!
    Mimikry
    Mimikry
    Reply 1 year ago
    Thank you!
    If you make one yourself make sure to show us the pictures - it only takes one hour to make but makes a huge difference on cleaning :)
    jessyratfink
    jessyratfink
    1 year ago
    This is a great way to make your own! I bought a "pet hair" squeegee that's really similar and works awesomely on my couches :D
    Mimikry
    Mimikry
    Reply 1 year ago
    Thank you for your comment!
    It get's all the fine feline hair and all breadcrumbs I leave behind :)
    And it is easy to make it.
    the most crutial part is to find the right kind of foam.
    Artmind
    Artmind
    1 year ago
    What a great idea here! I've been putting various foamy pieces & grabby things like a wet cloth over my current swiffer broom...
    Mimikry
    Mimikry
    Reply 1 year ago
    Glad you liked the idea :) - looking forward to your own model!
    AnandM54
    AnandM54
    1 year ago
    Oh cool brush !!!
    Mimikry
    Mimikry
    Reply 1 year ago
    .... it's free and works brilliantly :)
    Thans for your comment.
