DIY Pipe Shelf
About: Hi! I’m Heidi. On my page, you will find DIY projects; from woodworking, to concrete work. I love creating and sharing my experiences with you. Subscribe to my Youtube channel to see more super trendy, budge...
If you watch many videos on my channel, you'll likely come across a pipe project or a shelf project but today I'm combining the best of both worlds to bring you the industrial style Pipe Shelf!
JOIN ME ONLINE:
Instagram: https://www.instagram.com/timberandtea_
Website: https://www.instagram.com/timberandtea_
Click here so you don't miss a video! https://bit.ly/2Xe639L
Teacher Notes
Step 1: Cut Shelves
The first thing we're going to do is cut our shelves. I used two 10ft 1x10s in pine and cut them to length.
My shelves are going to be 36" wide.
Step 2: Holes
Once I got my boards cut, I measured out where my holes were going to go for my pipe to fit through.
I put mine 4 5/8ths" (half the width of the board) and then 3" in from the side.
Then I used my drill press with a 7/8ths" forstner bit. You could also use a spade bit in a regular drill if you don't have access to a drill press.
I drilled my boards 2 at a time to try and keep the holes as lined up as possible.
Step 3: Finishing Your Boards
Then I sanded down all the boards with an orbital sander (you could also use sandpaper, a palm sander, or skip this step altogether). I finished with 150 grit pads.
Then I used Provincial stain by Varathane to finish them off. You can also add a couple coats of sealer on top for a more durable finish.
Step 4: Pipes
Now that the shelves are done, it's time for the pipes! I used 1/2" black steel pipe, but you could use 3/4" pipe if you wanted a more bulky look.
These black steel pipes are usually a bit greasy so I gave them all a wipe down with some paint thinner. You could also use acetone or dish soap.
While my shelves were drying, I put together most of my pipe parts to make the final assembly easier. I assembled all of the parts that go in between the shelves as well as the 4 corner pieces that attach to the wall.
Step 5: Assembly
I assembled my shelf on a large, flat surface.
To install, I was able to screw mine into studs, but if thats not an option, you just have to use drywall anchors.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
