DIY Portable Soldering Iron Station
About: Nice to meet you my friends. Visit my Youtube Channel for get more instructable My youtube channel: https://www.youtube.com/c/longtechnical
I try to make Portable Soldering Iron Station. it can reach about 4 hour with 12V 4A battery part inside or use 220V input. I use 12V 15A Switching PSU, 12V battery part,12 to 24V boost circuit, hakko station circuit. The privous instructable about 24V power supply and hakko station below.
https://www.instructables.com/id/220V-to-24V-15A-P...
Home Make Hakko Station, Soldering Station New Project 2018
How to build SMPS transformer | Home make 12V 10A switching power supply | SMPS transformer.
Make 24V 15A switching power supply from OLD Computer PSU V1
Make 24V 15A switching power supply from OLD Computer PSU V2
Home Make 24V 30 Amperes DC Motor Speed Controler
You can download all file here PCB,Schematic,Gerber file for you can order PCB online. I alway upload gerber file to JLCPCB.COM for get PCB with only 2$for 10PCB.
Step 1: Make a Box
I use wood for make the box and drill my hole for put potentiometer
Step 2: Solder All Component and First Test
I connect all components together like picture below. The battery can charge with battery charger ciruit below.
Step 3: Finish and Use Battery Inside for Test
I have a switch to switch between battery and input source
    • Pocket Sized Contest
    • Build a Tool Contest
    • Paper Contest
      Paper Contest
    DIY Hacks and How Tos
    6 months ago
    Nice design. I rarely need to solder something that is already close to an outlet. So a portable setup would be a big help.
