DIY Audio RCA Plug ( Male / Female) | Aluminium Made
Introduction: DIY Audio RCA Plug ( Male / Female) | Aluminium Made
About: Welcome to TechnoCraft. A better way to make things easier and cheaper. Make anything that gives you satisfaction. "If you can't afford to buy something you want, better build it your own" that's o...
Watch the video :
This is a Aluminium sheet made custom RCA Plug, both male and female. So you'll learn how to make one when you are out of plugs or your speaker one is broken. Now easily make one in home and replace the broken one or just use as a connector.
May be this project is a very easy and simple one though i share this because i thought you might have faced these kind of troubles like me before. So from now do make it your own.
Step 1: Things You Need
Just few sort of things you gonna need to help your making,
Materials :
  • Aluminium sheet
  • Black Tape
  • Some Wires
Tools :
  • Scissor
  • Brush or Pen (width nearly to plug)
  • Plier
  • Plus
Buy Products :
Rca male to female : https://amzn.to/2NxLEEu
Gold audio adpter : https://amzn.to/2N3C7rT
Male to dual rca : https://amzn.to/2N3C7rT
Rca to female audio : https://amzn.to/2N3C7rT
3.5 mm to two rca : https://amzn.to/2N3C7rT
3.5 mm audio splitter : https://amzn.to/2N3C7rT
3 rca male to male AV cable, TV : https://amzn.to/2N3C7rT
Step 2: '+' Ve and the '-' Ve Plug
    Just cut the Aluminium sheet to the desired width and a prox. length.
    Now Place a brush in middle and roll the sheet over the brush, it will take a cylindrical shape with both ends open, but at one end keep a small piece of sheet so the wires can be fitted later on.
    Do the same with the positive plug only small in diameter, a refill width is good for the inner plug. Also tape around it.
    Its some complicated to elaborate in writings, so please watch the video, its clearly explained there. Also take help of images, you can get a better visualization of what you are making.
    Like this you can make more male or female rca plugs according to your need.
    Step 3: Connect & Finish
    Now our plug is ready to be connected, take some wire and fix to the ends of both positive and negative plug and connect it to your speaker and amplifier or wherever you need. Its not very hardly steady but it'll take your work going on.
    Metalworking Contest
    Be the First to Share
      • Pocket-Sized Speed Challenge
      • Audio Challenge 2020
      • Maps Challenge
        Maps Challenge
