DIY RGB LED Lamp
254
Introduction: DIY RGB LED Lamp
About: DIY & Electronics Projects, Craft Making, Video & Photo Editing
I Made LED lamp using Acrylic Glass.
Items we Need
1. Acrylic Glass
2. RGB LED Strips and Controller
3. styrofoam sheet
4. Hot glue, Strong Glue
5. Marker, acrylic cutter, knife, ruler
Teacher Notes
Step 1: Step 1
Need Acrylic Glass Sheet
Step 2: Step 2
Cut 3 three Pieces of acrylic glass different sizes or same as you want.
Step 3: Step 3
Take a marker and draw some pattern as you want, I draw Circuit board design.
Step 4: Step 4
take a knife or something pointed thing for scratch on acrylic glass,
and scratch the pattern that you draw.
Step 5: Step 5
after scratch has done, take off plastic wrapper on acrylic glass.
Step 6: Step 6
need a Styrofoam sheet for making lamp base,
Step 7: Step 7
make a triangle base like this, and cut 3 blocks for glasses .
Step 8: Step 8
after making base, paint it.
Step 9: Step 9
cut three pieces RGB LED from LED Strips.
Step 10: Step 10
Add the LEDs on bottom surface of base
Step 11: Step 11
solder LEDs parallelly
Step 12: Step 12
make a hole on side of the base and pass through the power outside.
Step 13: Step 13
solder a male header on power wires.
Step 14: Step 14
now attach glasses on base,
Step 15: Step 15
at last, plug power wires into the RGB LED controller and power the controller.
Step 16: Step 16
Finally LAMP is Ready for Play.
Light Off your Room and enjoy the Lamp
Step 17:
Be the First to Share
    • Finish It Already Speed Challenge
    • First Time Author Contest
    • Leather Challenge
      Leather Challenge
