DIY Rainbow 3D Printing Filament
6,123
56
7
Introduction: DIY Rainbow 3D Printing Filament
About: I'm a maker, artist, 3D printing enthusiast and love to work with Fusion360. If you like what I'm doing, feel free to follow me on Twitter @DasMia3
Have you ever wanted to create your own rainbow filament, but you don't have a device for it?
Now you can just print it yourself!
Here is what you need:
  • a 3D printer (bed size at least 205mm x 205mm)
  • Clear PLA filament
  • PLA filament in any color you like (for the rainbow: red, orange, yellow, green, blue, violet)
  • a slicing software (here: Prusa Slicer, but others will work as well)
  • The STL files for the filament (both single extruder and multi material)
  • Optional: Fusion360 if you want to create one for other bed sizes
The resulting filament is shaped hexagonal and printable with any 3D printer.
The transitions are shorter than on the rainbow filament your can buy, which allows you to print even small objects with many colors.
Are you ready?
Let's begin!
Step 1: The Correct Files Suitable for Your Printer
First you need to find the correct files for your printer:
Do you have a multi material device, like the Palette or MMU?
Follow the steps 2 + 3
Do you have a single extruder?
Follow the steps 4 + 5
Do you want to start from scratch and learn how to design this kind of filament?
Follow the video tutorial in step 6
Step 2: Multicolor Filament for Multi Material Devices
Follow this link to MyMiniFactory and download the files.
For multi material printing you will need these 15 files:
  • 01_Hex_Filament_9.5_Meters_Multi_Bottom_0.2_V01.stl
  • 02_Hex_Filament_9.5_Meters_Multi_Color01_V01.stl
  • 03_Hex_Filament_9.5_Meters_Multi_Color02_V01.stl
  • 04_Hex_Filament_9.5_Meters_Multi_Color03_V01.stl
  • 05_Hex_Filament_9.5_Meters_Multi_Color04_V01.stl
  • 06_Hex_Filament_9.5_Meters_Multi_Color05_V01.stl
  • 07_Hex_Filament_9.5_Meters_Multi_Color06_V01.stl
  • 08_Hex_Filament_9.5_Meters_Multi_Color07_V01.stl
  • 09_Hex_Filament_9.5_Meters_Multi_Color08_V01.stl
  • 10_Hex_Filament_9.5_Meters_Multi_Color09_V01.stl
  • 11_Hex_Filament_9.5_Meters_Multi_Color10_V01.stl
  • 12_Hex_Filament_9.5_Meters_Multi_Color11_V01.stl
  • 13_Hex_Filament_9.5_Meters_Multi_Color12_V01.stl
  • 14_Hex_Filament_9.5_Meters_Multi_Color13_V01.stl
  • 15_Hex_Filament_9.5_Meters_Multi_Upper_0.92_V01.stl
Load them into your slicer/print software.
Use the following print settings:
  • First layer: 0.2 mm height
  • all other layers: 0.12 mm height
  • no brim/skirt/raft
  • infill 100%
  • circular infill pattern
  • no supports
Assign your desired colors to the files, but file 01 (bottom) and file 15 (upper) need to be printed in clear filament.
This is to create a smooth surface on top and bottom, so the filament is printable when it's done.
Export your G-Code and print your filament.
Watch Step 3 in this video, if you want to see how it is done for the Prusa MK3S with MMU2 (Step 3 starts at 3:25):
Step 3: Printing Your Hexagonal Filament
Congratulations! You've successfully printed your very own multicolor filament!
I bet you can't wait to try it.
Hexagonal filament prints different to the usual one. So please watch this little video first, to make sure everything works:
I hope you enjoyed my instructable.
Now have fun with your very own multicolor filament!
Step 4: Multicolor Filament for Single Extruder
For single extruder printing you will need these 27 files:
  • 01_Hex_Filament_9.5_Meters_Bottom_0.2_V01.stl
  • 02_Hex_Filament_9.5_Meters_Red_0.32_V01.stl
  • 03_Hex_Filament_9.5_Meters_Orange_0.32_V01.stl
  • 04_Hex_Filament_9.5_Meters_Yellow_0.32_V01.stl
  • 05_Hex_Filament_9.5_Meters_Green_0.32_V01.stl
  • 06_Hex_Filament_9.5_Meters_Blue_0.32_V01.stl
  • 07_Hex_Filament_9.5_Meters_Violet_0.32_0.44_V01.stl
  • 08_Hex_Filament_9.5_Meters_Blue_0.44_V01.stl
  • 09_Hex_Filament_9.5_Meters_Green_0.44_V01.stl
  • 10_Hex_Filament_9.5_Meters_Yellow_0.44_V01.stl
  • 11_Hex_Filament_9.5_Meters_Orange_0.44_V01.stl
  • 12_Hex_Filament_9.5_Meters_Red_0.44_0.56_V01.stl
  • 13_Hex_Filament_9.5_Meters_Orange_0.56_V01.stl
  • 14_Hex_Filament_9.5_Meters_Yellow_0.56_V01.stl
  • 15_Hex_Filament_9.5_Meters_Green_0.56_V01.stl
  • 16_Hex_Filament_9.5_Meters_Blue_0.56_V01.stl
  • 17_Hex_Filament_9.5_Meters_Violet_0.56_0.68_V01.stl
  • 18_Hex_Filament_9.5_Meters_Blue_0.68_V01.stl
  • 19_Hex_Filament_9.5_Meters_Green_0.68_V01.stl
  • 20_Hex_Filament_9.5_Meters_Yellow_0.68_V01.stl
  • 21_Hex_Filament_9.5_Meters_Orange_0.68_V01.stl
  • 22_Hex_Filament_9.5_Meters_Red_0.68_0.8_V01.stl
  • 23_Hex_Filament_9.5_Meters_Orange_0.8_V01.stl
  • 24_Hex_Filament_9.5_Meters_Yellow_0.8_V01.stl
  • 25_Hex_Filament_9.5_Meters_Green_0.8_V01.stl
  • 26_Hex_Filament_9.5_Meters_Blue_0.8_V01.stl
  • 27_Hex_Filament_9.5_Meters_Violet_0.8_V01.stl
  • 28_Hex_Filament_9.5_Meters_Upper_0.92_V01.stl
Load them one by one into your slicer / printing software and make sure the positioning rings on top left and bottom right are alligned in each file. If you center them all on your buildplate, they should be alligned.
  • infill 100%
  • no supports
Create a G-Code for every single file.
Print all 28 files in exactly the order they are listed here.
Print the color files in the color that's written in the file name.
Start printing with file 01 in clear
change filament to red
print 02
change filament to orange
print 03...
and so on until you come to 28, which should be printed in clear again.
Make sure to keep the printbed hot while changing the filament!
Watch Step 3 in this video, if you want to see how it is done for the Prusa MK3S (Step 3 starts at 7:41):
Step 5: Printing Your Hexagonal Filament
Step 6: Creating Hexagonal Filament From Scratch
If you want to create this kind of filament for a different bed size or if you just want to know how it is done, watch all 5 videos one after the other:
Colors of the Rainbow Contest
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    7 Discussions
    LloydF3
    LloydF3
    1 year ago
    Clever!
    imakealot
    imakealot
    1 year ago
    So cool! Voted!!
    DasMia
    DasMia
    Reply 1 year ago
    Than you very much!
    Glad you like it. :-)
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    This is an interesting idea! I might have to give it a try :)
    DasMia
    DasMia
    Reply 1 year ago
    Thank you! :-)
    PotentPrintables
    PotentPrintables
    1 year ago
    Great work, I look forward to trying this out!
    DasMia
    DasMia
    Reply 1 year ago
    Thank you! :-)
