Introduction: DIY Rainbow RGB Led Tree
Nice to meet you again. Today I share with you how to make a beautiful night light. Night lights use Rainbow RGB Led to change colors themselves. The light will turn on automatically when it is dark. The necessary components I will list below, wish you success.
Thank you for visiting my YouTube channel. It is great pleasure to meet you. I wish you and your family good health and happiness.
Step 1: Components Needed
1. Rainbow RGB Led
https://www.banggood.com/100Pcs-F5-5mm-Slow-Flash-...
2. TP4056 Lithium Battery Charging
https://www.banggood.com/TP4056-Micro-USB-5V-1A-Li...
3. Plastic Shrink
https://www.aliexpress.com/item/32862162269.html?s...
4. MT3608 Booster Power Module
https://www.banggood.com/1pcs-MT3608-2A-DC-DC-Adju...
5. Hot glue, wires, soldering iron
That is all we need. Let's start.
Step 2: Let's Start
- I use pre-cut heat shrink sheet. If you can't buy them, cut them to the shape in the clip, not exactly.
- You can also use pet bottles. Each material will have different shrinkage rates. It will take you several times to get used to this.
- I use a hair dryer and it works perfectly. If you have a hot air blower it will help your work faster.
- Pay attention to shape your flowers when heated.
- You can also color them with crayons. Pay attention because the plastic will shrink so you do not need to paint too much.
Step 3: Step 2
- After creating petals successfully. We will mount the led on them. I use hot glue gun.
- I wandered in the garden and found a dry twig. This is probably the hardest job. A dry branch that fits your flowerpot is not easy.
- Our flower is complete. It looks pretty cool, right? Let's go to step 3. Add more electricity to make it more sparkling.
Step 4:
- I use wires taken from inductor. This cord is quite small, you will not need to hide them. And it also has good quality.
- This is an electrical circuit diagram that lights up automatically when it's dark. Your flowerpot will turn on automatically, you can use it as a night light, that's great.
- The connection part is quite simple: Battery ---> TP4056 ---> MT3608 Booster Power Module ----> Auto light circuit ---> led
Good luck
Indoor Lighting Contest
