DIY Relay Module Making
About: Subscribe Here: https://www.youtube.com/channel/UCJoXoKcfAo4j9XWDlxCWMyg
First Watch The Full Video Then You will understand Everything.
Teacher Notes
Step 1: 12V Relay
Step 2: PCB Board
I have used Dot PCB Board.
Link
https://ouo.io/S3Kmfs
https://amzn.to/2s02OSD
Step 3: Any PNP Transistor
Use any PNP Transistor Which Can Handle 20mA At least.
I have used BC557
Link:
https://ouo.io/IV0A4J
https://amzn.to/2GE71jg
Step 4: PC817 Opto-Coupler
Step 5: Resistor
Step 6: PCB Mount Screw Terminal Block
2 PIN PCB Mount Screw Terminal Block Connectors - Green
Link https://ouo.io/c41zSS
Step 7: Push Switch
Push Switch Link https://ouo.io/3MeONr
Step 8: Indicator LED
Green LED Link https://ouo.io/kIXm25
Step 9: Full Made Board From Front Side
Step 10: Soldering of Each Channel
Step 11: Circuit Diagram
Step 12: Single Module Connection With Arduino.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
