DIY Relay Module for Arduino
Circuit project files: https://easyeda.com/ritwickdj/relay-m...
Arduino Code: https://drive.google.com/open?id=1Rpb... Previous video: https://youtu.be/h6bOPBaKeVg Facebook: https://www.facebook.com/sinkingvibes.in Twitter: https://twitter.com/i_ritwick
Websites which were shown during the video: https://easyeda.com/ https://lcsc.com/ https://jlcpcb.com/ https://arduino-info.wikispaces.com/N...
In this tutorial I will show you how you can make your Own DIY relay module which works with Arduino or any microcontroller. Along the way I will show you that it is actually quite simple nowadays to order PCBs from a professional manufacturing house.
Thanks to JLCPCB for sponsoring this video Visit https://jlcpcb.com to get professional PCBs for low prices
For this project I used • 4 X 5v relays • 4 X 3v LEDs • 4 X BC547 Transistor • 4 X 1N4002 Diodes • 8 X 1K Resistors • And 6 Male headers • 4 X 3 combo screw terminals
Step 1: Plug in the Relay's and Solder Them to the PCB
Step 2: Add the 1n4007 Diodes and Solder
Step 3: Add the BC547 and Solder Them
Step 4: Plug in Female Headers to the Relay Module
Step 5: Power the Relay Module Using the Power Pins of the Module to the Power Rails of the Breadboard
Step 6: Power the Total Project Using a Micro USB Breakout Board
Step 7: Plug in the IN Pins of the Relay Module to the Breadboard to D 9,10,11,12 of the Arduino
Step 8: Now the Relay's Would Activate in the Sequence of 1 to 4
Arduino Code:
int IN1=12;
int IN2=11; int IN3=10; int IN4=9;
// the setup function runs once when you press reset or power the board void setup() { pinMode(IN1, OUTPUT); pinMode(IN2, OUTPUT); pinMode(IN3, OUTPUT); pinMode(IN4, OUTPUT); }
// the loop function runs over and over again forever void loop() { digitalWrite(IN1, HIGH); delay(1000); digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH); delay(1000); digitalWrite(IN2, LOW);
digitalWrite(IN3, HIGH); delay(1000); digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH); delay(1000); digitalWrite(IN4, LOW); }
Step 9: Watch the Video
    • Toys Contest
      Toys Contest
    • Warm and Fuzzy Contest
    • Comfort Food Challenge
