DIY Side Tables With Fabric Magazine Rack
2,544
29
Introduction: DIY Side Tables With Fabric Magazine Rack
About: Hey! This is Molly and Dylan from the YouTube Channel Woodbrew:) We are 20 year old makers, entrepreneurs, and content creators. Happy building!
We decided to make matching side tables with a fabric magazine holder because it was something simple enough to make in a couple days and it just sounded like such a cute idea.
This project is super simple to make and only requires one 8' 2x2 and 24" of a 1x12. We were already making two of these tables, so we bought 1x12x4 for the tops and just cut it in half.
Step 1: Cut All Pieces to Length
First, we cut all the pieces to length. We cut 4 legs, 2 long stretchers and two short stretchers. After that, we decided to do half lap joints to connect the stretchers to the legs. This will allow the ends to stick out a little bit in the end product. This can be done with a hand saw, circular saw, or the easiest tool, a table saw, which is what we used.
Step 2: Cut Out Half Lap Joints
We marked 1" from the ends of the stretcher to make that 1" over hang on the corners. Then marked over 1 1/2" from the first mark, this is what we will be taking out for the half lap.
Raise your blade to half the height of the 2x2, then make several cuts between your marks to clear away most of the material. Then it's super easy to break away what's left and then use a chisel to flatten the surface. Repeat this process on the rest of the boards. Do each side on the stretcher, but only on one side of the legs.
Step 3: Drill Pocket Holes
Next, we drilled out pocket holes to connect the long stretchers to the legs.
(Pocket Hole Jig we used: https://amzn.to/2DFS0S0 )
Step 4: Round Over Edges
Last thing we did was round over the outside corner of the legs, and all the edges of the long stretchers with the router table. That way the fabric doesn't rip over time on a sharp edge. This also could be done with sand paper or sander.
Step 5: Assembly
Assembly time! We glued and pin nailed the half lap joints together. Make sure the rounded edges of the legs are facing the outer sides. Next, we attached the long stretchers with pocket hole screws.
For the tops, we added a couple strips on the underside to keep it from falling off and so it will be able to slide back and forth and then also can be taken off for a lap table. We just used glue and pin nails to attach them.
Step 6: Finish
For finish, we used shellac because we were in a hurry and this stuff dries pretty fast. Feel free to do a fun stain or paint!
Step 7: Sewing
Then we sewed our magazine holder. We chose a faux leather, we think this color with a natural looking wood really works well together. We sewed the edges nicely and folded the sewed the ends over to make a loop for the 2x2 stretches to go through.
Step 8: All Done!
And then we were done! Super fun and easy project for a day's work.
Furniture Contest 2018
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    JT Woodworks
    JT Woodworks
    1 year ago
    Beautiful design guys!! That sling came out looking great
