DIY Small Basket
It's a small basket that needs little or no money or work. All you need is the following:
Yarn
Scissors
A cup that can break with little effort
Needle
Teacher Notes
Step 1: Make the Holes
Simply use the needle to create small holes on both sides of the cup. Be careful, as if the holes are not centered evenly then the cup will be unbalanced.
Step 2: Creating the Handle
Take the end of the yarn and push it through both holes.
Step 3: Cutting the Handle
Cut the yarn off so that each end of the yarn is equal.
Step 4: Tying the Handle.
Tie the two ends of the basket. You may need to cut some yarn off to make it even.
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
